Step 3Cutting the Barrel Straps
iImage Information
In order to cut the wooden barrel, a track must be cut in the metal straps. The easiest way to do this is by using a dremel tool with a metal cutting attachment. However, it is important to first secure the strap so that it stays in place after it is cut. This is done by drilling a hole on each side of the planned cut and putting in a glue coated 1/2" pan or wafer headed screw. Once all 8 screws have been put in place, it is time to cut the banding. Cut an inch and a half section out of the banding to give plenty of room, keeping in mind that a smaller cut is more aesthetically pleasing.
I suggest using a dremel, but there are many options available: a grinder with a metal cutting wheel, a jig saw (if you are exact), or maybe even a pair of tin snips or a hack saw (both of these would be difficult, but we work with what we have).
