Step 4Cutting the Barrel
iImage Information
For the barrel cut, it is best to use a table saw. Align the fence to hold the bottom of the barrel in the middle of the blade, and raise the blade up to about 2 inches, and make the bottom cut first. Once the bottom cut is complete, line up the blade with one of the corresponding cuts on the side of the barrel and lower the blade to about an inch and cut the side. It is important to be aware of the metal banding while cutting the sides. Once one side is complete, repeat the cut method on the other side.
This is again something that several tools could accomplish. A hand saw (bit of elbow grease), jig saw, reciprocating saw or band saw would also be able to get this done. You may want to draw a cut line as a guide if you use any of these methods. REMEMBER to be familiar with the tools you use and use them safely.
