3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build an attractive, space saving upside down planter.
Step 6Cutting and Finishing the Barrel
  • last photo ←
Finishing the backing of the barrel is not completely necessary, but it offers a nice touch. These barrels were coated on each side with a Minwax stain, but if you used redwood you would not need to do this. Reseal the barrels again after staining to help the planter last longer.
Cut a hole for the plant to grow through by using a 2 1/2 inch hole saw bit and a drill to cut the center hole. Start drilling the hole from the inside of the barrel, but switch to the outside before you cut all the way through. This will prevent any splitting or fraying form occurring when the bit cuts through. Depending on how well the middle of the barrel was caught, you may need to re-drill the second watering tube hole. Re-drill using a 5/16"-3/8" drill bit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:pagan209
