Step 7: Rear cage.
so draw up some plans that will make the rear cage.
two support rings one large one roughly the the same size as the holding.
i had ten slots for the cage sections to clip into and the smaller ring shows ten as well but it should actually have 20 as the smaller sections of the cage have to lock into that one aswell.
i cut two discs to finish the bottom of the cage. these were cut out of 1mm styrene.
you need 10 long supports and 10 half length supports. the half supports are the same as the long ones just with out the tp half.
assemble the cage. once it is all glued and the glue has dried spray the whole thing matte black.
cut a white disc that will be supported by the cage where it widens out. the disc has to be small enough to fit between the top supports and not too small to fall through the supports in the middle. (see the 5th picture.)
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
