How to build project "Fab" knex ball machine
 by Sorunome
Step 1: Piececount
Rods
green: 208
white: 210
blue: 417
yellow: 262
red: 119
grey: 42
black (same length as grey, you could youse a gray rod instead, but a black one is better): 1
Total Rods: 1259
Connectores
darkgray: 138
lightgray: 6
orange: 104
red: 112
green: 29
purpel: 301
yellow: 298
oange (you can connect tubing on them): 30
blue: 91
white: 50
Total Connectores: 1159
Other
orange clips to put tubing on: 5
blue spacer: 34
grey spacer: 26
tanclip: 5
Y-clip: 70
green-flexible rod (same length as gray rods): 1
orage-flexible rod (same length as yellow rods): 4
red medium-sized gear: 8
battery-motor: 1
chianlink: 94
261 cm tubing: 1
Total Other: 149
Total: 2567
Step 2: The frame
Ok now you'll build the frame
Step 4: The maze
Now you'll make at the right side the maze
Step 10: Spiral case and Wheal slide
It's time to make the spiral case and the wheal slide, an Element I invented.
Step 12: The last path
1-40 of 58Next »
poncho531 says: Jan 19, 2012. 4:43 AM
Wow! In step 3, part 8, it looks exactly like an optical illusion!
Sorunome (author) in reply to poncho531Jan 19, 2012. 5:44 AM
Maybe it IS one... :P:P:P
Knex1235 says: Dec 19, 2011. 4:43 PM
do you have a video
Sorunome (author) in reply to Knex1235Dec 21, 2011. 7:59 AM
No, sorry. Maybe you could make one?
poncho531 in reply to SorunomeJan 18, 2012. 5:22 AM
Mine won't exactly be good, because I prefer to film it in one video, but it will be fine. When I cover the camera with my hand, that's path seperation.
Sorunome (author) in reply to poncho531Jan 18, 2012. 6:32 AM
That doesn't matter.
Please do the modification in Step 12 (I didn't add that as comment yet as i somehow can't edit ibles atm) that you use in that helix thingy instead of two yellow connectors only gold ones and wined the track all the way, I haven't tested that but that should make it work better. :)
poncho531 in reply to SorunomeJan 18, 2012. 5:20 AM
I will! After I finish building it....
ryry2011 says: Feb 22, 2011. 9:32 AM
cool
Sorunome (author) in reply to ryry2011Feb 22, 2011. 9:36 AM
thanks! did you build it already?
ryry2011 in reply to SorunomeFeb 22, 2011. 9:39 AM
your welcome. no because me and the blue nullet made the final updates to my ball machine
Sorunome (author) in reply to ryry2011Feb 22, 2011. 10:08 AM
oh, i see!
ryry2011 in reply to SorunomeFeb 22, 2011. 11:37 AM
its still good thow
Sorunome (author) in reply to ryry2011Feb 23, 2011. 10:26 AM
thanks!
ryry2011 in reply to SorunomeFeb 23, 2011. 5:28 PM
yup
rollerbolder says: Oct 9, 2010. 1:45 PM
Sweet, i like it!!!!!!!
Sorunome (author) in reply to rollerbolderOct 10, 2010. 4:45 AM
Thanks!
rollerbolder in reply to SorunomeDec 26, 2010. 8:54 PM
no prob
knexpert#10829476 says: Sep 29, 2010. 9:32 AM
When I printed the instructions out on a dell laser printer, this step turned out black and barely noticable.
Sorunome (author) in reply to knexpert#10829476Sep 29, 2010. 9:53 AM
Sorry, but my light didn't work proper then, and I already took it apart. But on th computer you can still see waht it has to be.
oninoni says: Sep 25, 2010. 9:30 AM
..... i know this ball mashine sorunmie
Sorunome (author) in reply to oninoniSep 25, 2010. 10:52 AM
knexpert#10829476 says: Sep 24, 2010. 9:37 AM
Supports looks like it came from Temple Of Demise. They seem stronger than the square towers.
Sorunome (author) in reply to knexpert#10829476Sep 25, 2010. 3:11 AM
It came frome temple of dimense. :)
Tornado96 says: Sep 14, 2010. 2:34 AM
One more thing. You just earned a subscription. :-D
Sorunome (author) in reply to Tornado96Sep 14, 2010. 4:59 AM
Thanks. :)
Tornado96 in reply to SorunomeSep 14, 2010. 5:21 PM
Sorunome (author) in reply to Tornado96Sep 21, 2010. 5:07 AM
:-D (did you notise that this smiley has a nose? ;P)
Tornado96 in reply to SorunomeSep 21, 2010. 3:10 PM
Now your smilee can smell! HOORAY!
Sorunome (author) in reply to Tornado96Sep 22, 2010. 8:46 AM
:D (no nose)
Tornado96 in reply to SorunomeSep 22, 2010. 2:52 PM
BTW You're my 700TH COMMENTER!!! CONGRATS!
Sorunome (author) in reply to Tornado96Sep 23, 2010. 8:40 AM
Tornado96 in reply to SorunomeSep 23, 2010. 1:33 PM
:-D
Sorunome (author) in reply to Tornado96Sep 23, 2010. 10:27 PM
:D
Tornado96 in reply to SorunomeSep 24, 2010. 1:01 AM
Another eternal list of smilees! ;-)
Sorunome (author) in reply to Tornado96Sep 24, 2010. 4:42 AM
Also without noses ;P
Tornado96 in reply to SorunomeSep 24, 2010. 5:03 AM
Sorunome (author) in reply to Tornado96Sep 24, 2010. 5:33 AM
(removed by a smiley)
Tornado96 in reply to SorunomeSep 24, 2010. 3:11 PM
Not this again.
Tornado96 says: Sep 14, 2010. 2:27 AM
This looks similar to temple of demise. ;-)
Great job!
Sorunome (author) in reply to Tornado96Sep 14, 2010. 4:58 AM
What do you think had the Idea frome?
1-40 of 58Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
