Introduction: How to Build Project "Fab" Knex Ball Machine
Hello, This is an Instruction how to build my ball machine "Fab". I Hope you'll like it!
Step 1: Piececount
Rods
green: 208
white: 210
blue: 417
yellow: 262
red: 119
grey: 42
black (same length as grey, you could youse a gray rod instead, but a black one is better): 1
Total Rods: 1259
Connectores
darkgray: 138
lightgray: 6
orange: 104
red: 112
green: 29
purpel: 301
yellow: 298
oange (you can connect tubing on them): 30
blue: 91
white: 50
Total Connectores: 1159
Other
orange clips to put tubing on: 5
blue spacer: 34
grey spacer: 26
tanclip: 5
Y-clip: 70
green-flexible rod (same length as gray rods): 1
orage-flexible rod (same length as yellow rods): 4
red medium-sized gear: 8
battery-motor: 1
chianlink: 94
261 cm tubing: 1
Total Other: 149
Total: 2567
Step 2: The Frame
Ok now you'll build the frame
Step 3: Rolling on Rods
now you'll make on the left side the "rolling on rods" element.
Step 4: The Maze
Now you'll make at the right side the maze
Step 5: The Center
Now you'll make the center of the model.
Step 6: The Right Side
Now you'll make the right side.
Step 7: The Left Side
Now you'll make the left side.
Step 8: Flip Flap Thing and Ferris Wheal
Now you'll make two elements: the flip flap thing and the ferris wheal.
Step 9: The Tower
Now you'll make the tower.
Step 10: Spiral Case and Wheal Slide
It's time to make the spiral case and the wheal slide, an Element I invented.
Step 11: Archimedes Screw and Special Slide
Now yo'll make the archimedes screw and the special Slide.
Step 12: The Last Path
Step 13: The Chain
Now you'll make the chain.
Step 14: Finish
You finished buildeng Fab!!!
