3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a World's Smallest Electronic Shocker!
Step 2Slaughter the camera!
Now this is going to be a fairly dangerous part, open up the camera and get the circuit out safely without getting shocked by the capacitor...
First, pry open the camera's case apart with a flat-head screwdriver or just use your hands if you like, but you are more likely to get shocked by the capacitor.
After you taken the camera's case off, discharge the capacitor with a insulated screw driver, and you may get a big loud spark, and after that, the capacitor is discharged... (Use a screwdriver you hate so much, because a fully charged capacitor will leave a scar on the metal part of the screwdriver!)
Also, if you don't want to risk getting a shock from the capacitor, Gjdj3 recommends you to wear gloves, even the thin one will help he said.
Great! You had done the dangerous step on this instructable!
9 comments
Oct 20, 2011. 7:39 AMSharanga says:
To discharge the capacitor safely, you can use a fairly high-value resistor: this will allow a slower discharge and prevent the bright and loud spark. You will also avoid damaging your screwdriver shaft. This is especially important if you are playing around with very large capacitors taken from TVs, etc.
Hold the resistor safely with an insulated tool (be aware of insulation ratings) during the discharge; not with your bare hands. Touch the two wires of the resistor to the two wires of the capacitor, for a couple of seconds. After that, you can short the capacitor wires with a metal rod to ensure that it is fully discharged. Work safely.
Mar 26, 2011. 8:31 PMJustdoofus says:
Hey, I hope you're still on, Maybe we could get together and talk about this sort of stuff. Heh. I should really be posting this on your Orange board, or PM'ing. I am 15 aswell, I imagine you are probably around 16 now..
Mar 7, 2010. 5:08 PMbrooklynlord says:
I have a few questions:
First, what is the exact model of the camera that you used in the pictures?
Second, how many milliamps does the shocker put out?
Mar 10, 2010. 10:52 AMbrooklynlord says:
I thought 10 mA can kill you.
Mar 8, 2010. 7:45 PMbrooklynlord says:
I'm going to add another question:
Can a 130 mA 1.2 volt battery drive this? or a 300mA?
Mar 10, 2010. 8:26 PMbrooklynlord says:
Should i go with 2.4 volts 130mA or 1.2 volts 260 mA?
Mar 21, 2010. 5:22 PMbrooklynlord says:
If you want more pain from the shocker, do you increase the Voltage or Amperage?
What happens if you put a high current low voltage through the circuit?
Mar 10, 2010. 8:30 PMbrooklynlord says:
Also, have you tried the shocker with more than one battery?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
778
Author:Plasmana
 "Energy cannot be created nor destroyed!"
more »
