How to build the one motor walker!
Step 2How to build the one motor walker!
This is main mechanical part you will need to make the robot.
You can find this sort of gear in VCR. Search garage sale or ask familly and friends.
The DVD is already obsolete thank to the BluRay, imagine how obsolete is the VCR! :P
The gear in the picture is from a VCR.
If you are really lazy, you can buy it from there
http://www.allelectronics.com/make-a-store/item/GR-5/SET-OF-5-GEARS-AND-BUSHINGS/-/1.html
3 comments
Mar 7, 2009. 5:12 AMfa6oomi says:
from where can I find the material for robot pllz :)
Mar 29, 2009. 12:56 PMpsp3601 says:
You can get them at the store Addison of radio shack.
Mar 10, 2009. 8:51 AMsid_bet says:
Hello Jerome , Can i use the h-bridge using the 2n3904 and 2n3906 from beam online instead of the bicore ? Also do i have to insert a nail as in the last step . because the gear motor does not have a stop tab . Thanks.
Mar 12, 2009. 1:25 AMsid_bet says:
hello jerome, I have a 74hct240 . so can i connect the outputs of the bicore to the inputs of the h-bridge for more power ? Or will it work without the h-bridge ? Thanks
Mar 13, 2009. 11:37 AMsid_bet says:
hello jerome , I think i am a little confused about the wiring . while testing should i only attach power to the inputs or to the +ve and -ve in the diagram also .
May 20, 2009. 12:31 AMsid_bet says:
HELLO JEROME , I GOT THE BI CORE WORKING BUT IT TURNS MORE TOWARDS ONE SIDE THAN THE OTHER WILL THE NAIL SOLUTION WORK ? ALSO THE STRESS ON THE IDLER SHAFT IS CAUSING THE PIVOT TO BREAK OFF. THANKS
Mar 15, 2009. 11:42 AMsid_bet says:
hello jerome , i breadboarded the h-bridge circuit and it didn't work . then i realised that i had made a mistake in the connection of the transistors. i put the all emitters in place of collectors . i have read that connecting transistors wrong way cause them to destroy. will i have to buy new ones ? pls help. Thanks
Mar 14, 2009. 2:59 AMsid_bet says:
hello jerome, Okay so i connect power only to the inputs. got it Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
229
Author:robomaniac(www.JeromeDemers.com)
I am a French Canadian that loves robots and embedded electronics. I work on all kinds of cool projects, like a high-power electric push scooter controlled with an Arduino. Please visit my website fo...
more »
