3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build your first Robot ($ 85)
Step 3Buy the materials (Servo Upgrade Pack)
1 PICAXE Servo Upgrade Pack
-An easy way to get a servo topped with some small parts needed for this project.
You can also get any standard servo, the pins shown on the image, and a single 330 Ohm resistor instead of the yellow chip, if you should wish.
Price: 15 USD
Get the full package here
What is a Servo?
A Servo is a cornerstone in most robotic appliances. To put it short it is a little box with wires to it, and an axle that can turn some 200 degrees. on this axle you can mount a disc or some other peripheral that comes with the servo.
The 3 wires are: 2 for power, and one for signal.
The signal-wire goes to something that controls a servo, in this case that is the microcontroller.
Result is that the microcontroller can decide to where the axle should turn, and this is pretty handy; You can program something to physically move to a certain position.
15 comments
Jun 4, 2008. 4:39 PMub3rFrank says:
Does anyone know where I can get some of those pins? Is there another name for them besides just 'pins' ? Thanks
Jul 7, 2011. 10:04 AMjacquelbot says:
I've usually heard (in the US), those pins called "100 mil pitch headers" or "breakaway headers". The "100 mil pitch" part means that the pins are spaced 0.100" (2.54mm) apart (this is critical, trying to make the wrong sized header work is a huge pain). They're also called "breakaway headers" because you can easily cut the strip apart to get just the number of pins you need in a row. Digikey is once source, here's an example part number (they've got more, from different manufacturers and at different lengths): S1032E-16-ND
If you can find them at a local electronics store they're probably cheaper, but double check the pitch! (Can you tell I recently got burned on that one?)
Sep 4, 2008. 6:22 PMacidblue says:
What kind of 330 Ohm resistor should i get? 1w, 1/2w or 1/4w? or does it matter? Going with a standard servo and the 330 Ohm resistor since it's cheaper. Sorry if this is a stupid question, just want to make sure I get the right one.
Jul 7, 2011. 9:52 AMjacquelbot says:
Whoops, the difference between 1W, 1/2W & 1/4W is *not* accuracy, it's how much power they can take. If you're attaching the resistor to a pin of your microcontroller it probably doesn't matter, because the microcontroller can't source enough power to burn up a resistor, but other times it might matter a lot! This website has a nice discussion of power dissipation in resistors, including an experiment! http://www.allaboutcircuits.com/vol_6/chpt_2/7.html
Oct 14, 2009. 12:28 PMJinnarin says:
If you are in the US and looking for the yellow chip, I believe this isthe right one: www.alliedelec.com/search/productdetail.aspx
Sep 26, 2009. 9:37 AMarea36 says:
Does anyone know where to find those pins?
Mar 25, 2008. 11:51 AMdragonis says:
Do you need just one 330 Ohm resistor or 8 of them as a substitute for the yellow chip. Thanks
Jul 4, 2009. 12:35 AMElliot says says:
Can I use any servo?
Jul 4, 2009. 12:34 AMElliot says says:
can i use a simple servo
May 29, 2008. 4:59 PMlaconic says:
Hello, I'm been looking around I can't seem to find this "package" anywhere in the USA or Canada, could anyone help? If not could I get the names of each component in the package and I can just buy them separate, thanks in advance
Aug 27, 2008. 10:20 PMH-Bot says:
Hey fritsl do you think that if I mounted two leds on the IR sensor that it would be able to avoid objects during the night?
Mar 31, 2008. 7:23 PMmabright99 says:
How much do 330 ohm resistors cost?
Mar 24, 2008. 4:04 PMdragonis says:
Can you just use a standard 180 degree angle servo and a 330 Ohm resistor instead of this whole pack upgrade. What's the third thing? Just want to be clear.
Mar 12, 2008. 11:41 PMAndruha1123 says:
stupid question: whats a SERVO, and what does it exactly do?
Mar 14, 2008. 4:08 PMcool! says:
A servo is usually used to control a control surface on a RC plane, or to steer in a RC car. In robotics, They are used to move sensors, etc... Basically, a little motor in a gearbox.
Mar 13, 2008. 2:17 AMBongmaster says:
servos are what is used in radio control cars and planes. they are what move the throttle (on a glow plug engine), flaps and steering.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:fritsl
