loading
Step 3: Dismantling pipes and sink
Start by dismantling the drain pipe connected to the sink.
Before releasing the pipe place a bucket under  the pipes for draining left over water in pipes. Next open the hot and cold water pipe connections. Every tap and plumbing system is a bit different in my case I had to disconnect the pipes from both sides in order to be able to lift the sink and tap out.
If your sink has connectors under it release them with a screw gun.
Push connectors back and lift sink out. Release old tap with a spanner.
<p>http://www.cheaptap.co.uk/</p>
About This Instructable
92,419views
11favorites
License:
Bio: I have too many hobbies and never enough time <(°¿°)> My Metal Casting blog: www.flamingfurnace.com My Paracod projects blog: www.paracord-projects.blogspot.com-
More by NutandBolt:Aluminum star casting Foundry Sand Casting Ramming Tool Aluminium Foundry
Add instructable to:
