3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to change battery on Tom Tom One V3 SatNav
 My Tom Tom is about 2 years old and the battery has seen better days.  If the charger plug falls out whilst driving it last a matter of minutes before shutting down.  Although tempted to buy a whole new unit for a few more features I thought I would replace the battery.
It's a fairly simple operation but I struggled to find much on the internet to assist prior to starting so have written this to help others.
New batteries are available from ebay, search for "Tom Tom One V3 Battery" and you should find loads. Expect to pay about £8-£10 delivered.
You will also need a Torx 8 or T8 driver to remove the screws.  These are available in the UK from Maplins, B&Q and Screwfix, often in a combined security driver pack.
Before you start:
Remove any SD cards
Backup the TomTom using the TomTom suite software supplied with the unit.  You shouldn't affect any data on the unit but best be safe!
Step 1Remove screws and open case
Turn the unit over.  There are four T8 screws that need removing.
Once removed use your finger nails or an old credit card to open the case at the top, it splits between the silver and grey section as shown.  Once as shown the grey back section slider down off the unit to clear the SD card and USB port.
3 comments
Nov 20, 2009. 1:08 AMT2Pogi says:
Hi.
Thanks for the information.
what is the rated voltage of the battery ? i was considering changing the bat on my tomtom (same model as yours) this weekend. this advance how-to helps a lot.
g
Nov 20, 2009. 4:40 AMJoe Martin says:
It's 3.7 volts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:montythemole
