Step 2Lay out and remove old battery.
If you feel any resistance the wires are still retained in the cable clip and just need freeing up.
Now you need to free the battery. It is held down with a sticky foam pad. I found that inserting a slotted screwdriver in the now empty hole for the USB connector allowed me to work it loose. Be careful as if you go silly you could puncture the battery (unlikely though).
Once the battery is loose you need to disconnect the lead. This is a small three pin plug and needs to be gently pulled upwards away from the circuit board. You may need to work a small screwdriver in to release if very stiff.
Add Comment
