3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to change battery on Tom Tom One V3 SatNav
Step 3Install new battery and close up.
Once removed it's time to install the new battery.  I managed to carefully peel off the old foam sticky and re-attach to the new battery.  If you can't they use a double sided foam sticky pad or similar.
Make sure you install the battery with the power lead to the top left as per the original.  My battery is flipped here to show the sticky.
Insert the new battery and attach the plug to the socket on the circuit board.  The plug is 3 pin and must be connected the correct way.  If you look at the plug you can see the pins are offset so in theory will only connect the correct way.  However I'm sure with enough force you could mash it in the wrong way so take your time.
Once done bring the two halves together like a book, and route the two wires in the cable clip.  Then assembly is reverse of removal, slide the grey halve onto the silver half so the USB connector pokes out of the hole in the case.  If it looks correct snap shut and screw back together.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:montythemole
