How to Change Color in Command Prompt
Published
Introduction: How to Change Color in Command Prompt
Ok then, Everyone has to agree that the normal colors in command prompt are extremely boring, Dull Gray on boring Black... Not fun colors when you are wanting to mess about in command prompt.
So, I'm going to show you step by step how to bring some color into your prompt!
Step 1: How to Find the Colors
Ok, So first you need to find out what the codes for each of the colors are, to find this out simply type:
color zz
and then you will get an amazing list of colors.
Step 2: Looking at the Colors
You will now be provided with a list of colors, Here is a copy:
0 - Black
1 - Blue
2 - Green
3 - Aqua
4 - Red
5 - Purple
6 - Yellow
7 - White
8 - Gray
9 - Light Blue
A - Light Green
B - Light Aqua
C - Light Red
D - Light Purple
E - Light Yellow
F - Bright White
Step 3: Text Color
To change the color of the text ignore the first Hex Digit of the color (color --)
Basically each color combination is split into two Hex Digits, The second one is the color of the text, so if you would like light green text then you would need to do:
Color -a
The other Hex Digit will be explained in the next steps
Step 4: Background
So far you have a color decided for the text (a) now you just need to pick a color for the background that will be the first Hex Decimal, so if you want an aqua background with our light green text you just need to put 3 for aqua before the Hex Decimal for the text, for example:
color 3a
This will make the background aqua (3-) and the text light green (-a)
So just put the two together and you have the full command (3a)
Step 5: Other Combinations
You can try out all sorts of combinations!
Here are a few examples:
color 48
Red with Gray text
color 3b
Aqua with Light aqua text
color 7c
White with Light red text
color e4
Light yellow with red text
So have fun and just experiment with lots of random combinations to add a bit more fun into your command prompt!
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    That's great! Brings me back to my computer programming class days!
