Step 13Installation is the reverse of removal
Thread the boot onto the inner tire rod
Install the inner tie rod with the locking pliers
Stake the new washer
Pull the boot over the inner tire rod and secure it to the same place you unsecured it from
Put the outer tie rod back into the wheel assy.
Replace castellated nut
Put new cotter pin in
Put wheel back on
Notes:
With the inner tie-rod off of the car, slip or thread the boot on. I had to thread it on.
If the cotter pin wont come out, then break off what you can and torque it out with the 19mm socket.
If you can't get the remnants of the cotter pin out of the threaded rod on the outer tie-rod end, drill it out. I used WD-40 as a drill lube.
comment
Add Comment
Add Comment
