Estimated cost:
Oil $10-12
Filter $7
Estimated time: 30 minutes to an hour
Required Tools:
Car Jack or ramp to raise car
Crescent Wrench to remove bolts
A container to drain used oil
Towels, or rags of some sort (it can get messy...)
A funnel is useful, but not essential
Remove these ads by
Signing UpStep 1Identify Oil and Filter Required
Identify in your owners manual the viscosity (i.e the thickness or type e.g. 10W-30) and the amount of oil your car requires. The average price for one quart of oil is $2.50.
Oil Filter
The type of oil filter you need can be found in either your owner's manual or your local auto parts store can direct you to the right type.
By cutting the filter not only you will be able to look for metallic shavings or other contaminants, but it will allow you to MEASURE the actual paper surface of several brands of filters. You will be surprised to find some quite expensive brands that have a lot less paper than others. Quality of the pressure relief valve and other aspects. Don't be fooled to buy "original" oil filters from car manufacturer, some are as bad as possible and actually are made by filter companies at the lowest possible cost!
I use Wynn's Oil System Cleaner put into the used oil before draining it, because idling the engine for 5 minutes with this product helps maintain all the small oil passages in my turbocharged engines open and free from carbon deposits. Draining is also helped because this product lowers viscosity a little more, and engine is protected because it contains extreme pressure additives. (Con't use it in a completely new engine to help the piston rings seat properly!). I was surprised to find a mexican made oil filter with better internals and much more paper surface than otherwise more famous ("Infamous") brands, specially one that has an orange color paint finish and a rubberized end to help with hand grip... looked fine on the outside, but was the worst of several inside!.
