3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to change your oil
Step 5Replace with a new oil filter
Screw new oil filter into the place where you just removed the old one.
2 comments
Dec 4, 2008. 10:13 PMGodsLove says:
do you change oil filters anytime you change the oil?
Jan 13, 2011. 1:59 PMamclaussen says:
ABSOLUTELY! There is almost a quarter of a gallon of dirty used oil inside the filter, just waiting a cold day morning when you are rushing to work, thus the cold oil increases its viscosity several times from the cold, and the fast turning engine pumps the filter contents around the pressure relief valve directly into the fresly changed oil !!! ALWAYS CHANGE THE FILTER TOGETHER WITH THE OIL CHANGE, each and every time.
Dec 30, 2008. 7:37 PMeskimojo says:
Also, some particulates can get through an old filter(like metal particulates) that can damage your engine, that's mostly in a "worst case scenario" though.
Dec 30, 2008. 7:36 PMeskimojo says:
You don't have to, but it is greatly suggested especially as waste particulates in the filter can slow oil flow which will reduce the efficiency of the sump system. Not only that but you will be running clean new oil through a nasty old dirty filter... it's like washing with new fluid but an old dirty rag.
May 13, 2008. 8:19 AMgripen40k says:
You should always 'wet' the rubber ring on the inside of the new oil filter with fresh oil before installing it. This helps maintain the life of the rubber o-ring and prevents leaks. I like the surgical gloves, have to get me some of those :).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:monkeys
