Introduction: How to Change Your Windows 7 Default Login Wallpaper
Picture of How to Change Your Windows 7 Default Login Wallpaper
If you want to change the default login wallpaper of windows 7 [the blue wallpaper] to any picture you want, heres how,
Step 1: STEP 1
Open the start menu and in the search box, type:
REGEDIT
open the program that comes.
click yes on the confirmation that comes, if you added a password, type it.
Step 2: STEP 2
Picture of STEP 2
Right click on HKEY_LOCAL_MACHINE and select Find
Search for OEMBackground.
Step 3: STEP 3
Picture of STEP 3
Double click on the entry OEMBackground, and change the value from 0 to 1
Step 4: STEP 4
%windir%\system32\oobe
go to this location from windows explorer, by copying it and pasting it there
Step 5: STEP 5
Picture of STEP 5
create a new folder named info and open it
create a new folder inside info named backgrounds
Step 6: ADDING THE PICTURE
Picture of ADDING THE PICTURE
place it inside the backgrounds folder that you created in the last step
THE PICTURE SHOULD BE LESS THAN 245KB IN SIZE
Step 7: AND YOU'RE DONE
just restart or put your computer to sleep or just lock it and you'll see the picture
if you want to remove it simply delete the picture from the backgrounds folder that you created and the default blue login wallpaper for win7 will be back.
AMIRM37 (author)2016-02-22
thank you
BằngL1 (author)2015-08-07
thanks you
diegofenner (author)2013-02-03
simple and effective. thanks for the tips :)
samalert (author)2012-05-04
better than that use a software ..... one can search "windows 7 login screen changer"
a sample for such program http://tweaks.com/software/tweakslogon/
and above shown is the way but the program does the same so :P
NOTE : such utilities or applications must be started giving the admin privileges
by right clicking on application and selecting "run as administrator"
mohammad96jamal (author)samalert2012-05-05
why would you install third party apps if you can do it in 5min or less by yourself without any apps
thegeeke (author)mohammad96jamal2012-05-19
Because some people are scared of their registry, and some third party apps do more than just the background (such as ultimate windows tweaker). Granted, all of the things UWT does can be done manually in less than 5 min, but everything combined in one GUI makes it a whole lot easier. (Plus, it's a portable app... great for custom built computers.)
vicvelcro (author)2012-05-16
The registry key does not exist in my system. I presume it would only pre-exist on a system that is OEM. I have the full retail version of Windows installed, not an OEM system.
What is the full location of the registry key and are there any other keys that should go with it?
Thank you.
Nerko-erko (author)2012-05-06
nice instructable, if I was 6 years old.
Well sadly ur not 6
Jen sanko (author)2012-05-05
Thank you :)
i used the attached image
You're welcome
nice pic
Jakwiebus (author)2012-05-05
thank you for making my computer look awesome :D
you're welcome jakobus9
About This Instructable
55,476views
9favorites
License:
More by mohammad96jamal:How to install Windows 8 from a USB stickHow to change (increase/decrease) your computer's RAM manuallyHow to connect your PS3 controller to your computer
Add instructable to:
