3 Simple Ways to
Share What You Make
Other ways to share:
Solar Powered AA Battery Charger
by
sgeddy
Solar AA (NiMH) Battery charger
by
Deutschmann
How to Make a Solar Powered Powerwheels
by
knife_eye
Make a solar battery charger in 5min
by
Asa J
Solar Car Battery Charger DIY
by
TimAnderson
Making a 1 Watt Solar Array.
by
Josehf Murchison
Solar Power System
by
Mr. Chicken
Cheap solar powered iPhone charger
by
pauleway
30,182
views
Related: 12 volt battery, charge a battery, battery, charger, solar power, solar, solar charger, battery maintainer, recharge a battery, sun
Comments: 11
Rating: 3.97
© 2012 Instructables
All Steps Viewing
one thing to note. They come with a cigarette plug but use the alligator clips. Found out that some vehicles disconnect the cig outlet from the battery when the engine is shut off.
seconding what the other commenter said: this is a fine tutorial showig how a 12v battery can be boosted, but that or any tiny solar panel is only going to generate 250 ma or so in full sunlight . If you're charging a smallish 12v battery that is 25 ah (=25000ma). Even assuming all of the charge was retained by the battery (usually you need to put an extra 10 -20% in) you're talking 100 hours in the sun. Yes it could trickle/keep topped up, which is a great use for it - but not a normal charge from 'used last week' to 'I want to use it next week'.
Although IMO, a proper line-powered charger is the best bet in the "dead battery" situation, but a low-wattage solar panel is GREAT for keeping a rarely used lead-acid "float charged" so you're never in that situation in the first place. Otherwise self-discharge -> sulfation -> severely reduced battery life.
I use a 5W panel in my convertible which is pretty rarely driven, esp. in winter - I haven't had a single problem starting it in the 2 years since I started using the panel.
