Step 3The LED
Use the crank to light the led. If the led does not light however, the polarity was probably reversed which means you must crank the motor in the other direction. If it still doesn't light, check your connection.
Next, get out your multimeter. Wrap the two exposed wires around the two multimeter cords. Set your multimeter to the 20 volts DC setting and crank the motor. I got mine up to 13 volts which I think is pretty good for a tiny little hand crank.
Add Comment
