How to check AA/AAA alkaline battery using a voltmeter
 by msurguy
We all run into a situation when batteries in our remotes, toys, keyboards/mice run out. If we don't know how to check a battery we might throw out a perfectly fine battery (especially when we have a pile of them somewhere in the drawer).
This electronics tip has to deal with checking common alkaline AA/AAA batteries or AA/AAA rechargeable batteries for proper voltage with a voltmeter.
Disclaimer : some people might say that a battery should always be tested under load but I have found that in most common household applications this is insignificant and will not change the results of the testing too much.
Things that you will need :
+ Voltmeter
+ Alkaline battery
Basic facts :
The proper voltage for AA/AAA alkaline battery is 1.5V
The proper voltage for AA/AAA NiCd/NiMh rechargeable battery is 1.25 Volts
To test the battery, turn on your voltmeter, put the voltmeter on DCV and make sure that it is far above the battery voltage, on most voltmeters there is a setting "20" in the DCV area, so switch your voltmeter to that setting.
With the battery in front of you, put the red probe to battery's nipple (+) and the black probe to the battery's flat side (-). Notice the voltage reading on the voltmeter.
If the reading is more than 1.3V for alkaline battery (not rechargeable battery) then the battery still has some juice left in it, don't throw it away. Otherwise, properly discard of the battery.
Tip : do not use old and new batteries in the same device at the same time. Try to use batteries that have same amount of energy stored in them.
Another tip: I sort my batteries according to Voltages, 1.35+ Good, 1.2V-1.3V Ok (but almost out), 1V-1.2V Discard.
I will attach some pictures of measurements in action.
Instructions on how to use a multimeter are out of scope of this Instructable, you can find some information here: http://www.ladyada.net/learn/multimeter/
askjerry says: May 16, 2013. 12:27 PM
I'd like to offer a few corrections, additions, and pointers.
Testing a battery with a multimeter will only tell you what the voltage of an UNLOADED cell is. In other words... you could have two batteries that read with an identical reading of voltage... but when you connect them to a load... let's say a motor... one will spin niely and the other will fail... run slow or stall.
Why? Because the CAPACITY of the failed battery has diminished. Let's take the example of a AA battery... if it has a 2000mAh capacity, that means that it can support a load of 2000 mA for 1 hour... or 1000 mA for 2 hours. This means that if you were running a toy that drew about 200 mA... it would run for 2000mAh/200mA or 10 hours.
So how do you check the battery? Under a load. Let's use the example above... we don't want to draw 2000mA on the battery... that's a huge load all at once. But instead... let's draw 1/10 of it's capacity... 200mA. We can take the voltage 1.5 volts / 0.2 amps (200mA = 0.2A) and get 7.5 ohms. So if we find an 8 ohm resistor and put it across the battery... it should still be close to 1.5v... but if it drops way down... to less than a volt for example... then it is likely discharged or going bad.
Another issue with the 1.5 volt battery... a NON-RECHARGABLE battery is rated for 1.5v fully charged. but... a NiCad battery is rated for 1.2V FULLY CHARGED. And I believe a lipo is like 1.25V if memory serves me.
I actually use this fact in my projects... an Atmel runs 3.0v to 5.5v...
4 AA batteries.... at 1.5v = 6.0v which would be high for my 5v Atmel processor...
4 AA batteries.... at 1.2V = 4.8v which is just fine.
I hope that helps.
Jerry
spavan1 says: Jul 16, 2012. 3:20 AM
I general use my tongue to test the batteries,
It tastes sore when it has some power.
Am i rit?, dose it works?
ironsmiter says: Jul 12, 2012. 10:49 AM
1.2 volt and below is NOT a dead battery! In fact there is something like 25% of potential energy still sitting in there!
It's just a battery in need of a new project.
Might I suggest starting with a http://www.instructables.com/id/Make-a-Joule-Thief/ ?
True, anything below around 0.9V is deader than a door nail, but even then, you can get a surprising amount of work out of a cell. Probably a couple hours of light out of red led's.
msurguy (author) in reply to ironsmiterJul 12, 2012. 12:49 PM
Lol, that's very cool use of zombie batteries =) Thanks for attaching a link of a Joule Thief, I was wondering what those things were.
I'm sure there are lots of uses of at-the-grave's-door batteries but In most household cases the battery that's below 1.2V wouldn't be of much use, for example toys or even IR remotes don't like low voltages...
Thanks for your input Ironsmiter!
wfelix says: Jul 12, 2012. 9:29 AM
Sorry, didn't mean to be rude. It was unnecessary, apologize ;)
msurguy (author) in reply to wfelixJul 12, 2012. 12:40 PM
Apology accepted =)
wfelix says: Jul 12, 2012. 5:08 AM
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
