But times have changed. Digikey lists over 16000 different line items under a 'microcontroller' search. Which one should a hobbyist with no particular prior experience choose?
Here are some hints. These are particularly aimed at someone trying to pick a microcontroller to use for the first time at least partially as a learning experience, rather than someone who wants to accomplish a particular task.
Update 2009-01-28: This Instructable was recently mentioned in some popular blogs, and is getting a bunch of new readers. Be sure to read the 'comments' made by other readers and the responses to them; there's a lot of value in those comments...
Step 1: What IS a "Microcontroller" ?
- A Central Processing Unit or CPU. The part that actually performs logic and math
- Memory. Where the computer stores data and instructions
- Input and Output or I/O. How the computer moves data between its other components and the real world.
A microcontroller uses the same techniques to shrink the entire computer to a single chip (or very small module.) CPU, Memory, and I/O all in a little package as small as a grain of rice. Just connect up power and it starts doing its thing; computing and talking to the world. Usually the I/O on a microcontroller is aimed at "low level" hardware like talking to individual switches and LEDs instead of keyboards, internets, and displays (like your desktop computer.) A microcontroller is just the thing you want, if you want to talk to individual switches and LEDs...
Step 2: Show Stoppers
Programability and Reprogramability:
At this point in time, I would say that a hobbyist should only consider microcontrollers that have internal flash or eeprom program memory and can be erased and reprogrammed a substantial number of times. There are also micros that can be used with external memory (adds complexity and expense), UV erasable micros (usually quite expensive due to the special packaging), one-time programmable chips (potentially usable after you have a working design, but losing their price advantage anyway), and mask-programmed chips (essentially useless.)
Peripherals:
If you want your microcontroller to have built in Ethernet, CAN, USB, or even multiple serial ports, many common choices are going to be eliminated. Some peripherals can be handy to have: UARTs, SPI or I2C controllers, PWM controllers, and EEPROM data memory are good examples, even though similar functionality can frequently be implemnented in software or external parts.
It's convenient if output pins can supply reasonable amounts of current for driving LEDs or transistors directly; some chips have 5mA or less drive capability.
Physical packaging:
Hobbyists are somewhat limited is the packages they are able to deal with, from a prototyping, PCB fabrication, and/or soldering. That 256 ball BGA coldfire CPU may be sweet, but it's effectively unusable by mere mortals. Microcontrollers available in 0.1in DIP packages are much easier to deal with. Probably anything with a pin spacing smaller than 0.05in should be viewed with some skepticism.
Memory:
The size of memory may be an important consideration. Some micros have as few as 256 innstructions and 16 bytes of RAM. You can do a lot in that sort of space (believe it or not), but not everything. Moreover, while you can frequently upgrade to a "bigger chip", some chip families have relatively small memory limits imposed by their architecture, so even the biggest chip you can get will have only 8k instructions (for example.) RAM (data memory) is usually scarce in microcontrollers; some algorithms require substantial RAM to be implemented in a straightforward manner, and it may be worthwhile looking for a micro with a lot of RAM (or external RAM expansion capabilities) if that's the sort of thing you had in mind. (For instance, implementing TCP/IP networking protocols in a micro whose total RAM space is less than used by a typical ethernet packet is likely to be ... interesting.)
Step 3: Thoughts about Architectures
You will hear people talk about how some architectures are better than others. I suppose this is true. But I'm going to claim that it is largely irrelevant for the typical hobbyist. If you wish to avoid the architectural quirks of a particular family of microcontrollers, you can use a high level language. If you're willing to program in assembler, you're at a level of interest where learning and overcoming the quirks is party of the stuff you should be learning. Besides, we're not talking here about evaluating some new architecture that some company is proposing. All of the chips I mention in this instructable have been around long enough that they've proven that their architectures are good enough for MANY real applications.
Here are some architectural "features" you may read about and some explanation of what they mean.
CISC/RISC. Complex Instruction Set Computer. Reduced Instruction Set Computer.
In the old days, CPU designers were getting clever and wanted their CPUs to support high-level language features in hardware, leading to cobol-like string manipulation instructions that accepted arguments in blocks of 8 registers. IIRC, it was Berkeley and IBM who noticed that compiler writers didn't really know how to USE such complicated instructions from a compiler, the amount of silicon real estate used by these instructions was getting large, and in fact the hardware implementation sometimes wasn't as fast as doing the same thing in software anyway. So they said "I bet we can make the CPU go a lot faster if we leave out these complex instructions and dedicate the silicon to more registers or cache memory or something", and thereby invented the RISC CPU. Nowadays "RISC" is widely used by marketing departments to mean "we don't have very many instructions", even if the rest of the architecture isn't very much like the original RISC researchers had envisioned.
Harvard Architecture.
In a Harvard architecture, the instruction memory and the data memory are separate, controlled by different buses, and sometimes have different sizes. For microcontrollers, the instructions are usually stored in "read only" memory, and data is in RAM or registers. An example is the
PIC microcontroller, where instructions are in 12, 14, or 16 bit wide flash, and data is in 8bit
wide RAM.
Von Neuman Architecture.
In a von Neuman Architecture, data and instructions share memory space, so you could do things like dynamic compilation to generate instructions in RAM and then execute them. The TI MSP430 is an example of a von Neuman architecture.
Accumulator based
In an "accumulator based" architecture, there is usually one "special" register where most of the actual computation (math, logic, etc) occurs. Some effort has to be spent to get operands into the accumulator and results back out to where you need them. The opposite is a processor with "general purpose" registers, where any of several registers can be used for math/etc.
Load/Store
A load/store architecture typically means that operands to ALU operations have to be in registers, so that you have to load them from memory beforehand and store them back when operations are complete. The opposite typically allows operations between a register or
accumulator and a memory location directly. RISC architectures tend to be load/store, since a lot or the CISCness of CISC processors shows up in implementing complex "addressing modes" for accessing the memory operands. In a RISC architecture, all that complexity only has to be implemented in the load and store instructions (if at all.)
Registers
Memory Mapped I/O
Step 4: Thoughts about Hardware Tools
These vary wildly in cost. It's pretty common for manufacturers to offer some low-cost programmer so that people can "evaluate" their microcontrollers without risking too much cash (or requiring director level approval :-) "low cost" used to mean "less than $500" (which happens to be a common "expensable" limit), but the number has been going down. I think you can find manufacturer supplied development tools for most of the microcontrollers mentioned here for
$50 or less.
Cheaper tools can be bought from third parties, or built yourself. If you don't mind the possibility that bugs in your tools might cause more problems than bugs in your code.
Maximally, production gang programmers, In circuit emulators, logic analyzers, oscilloscopes, lab-bench power supplies... You can spend as much money as you've got, probably.
Step 5: Thoughts about Software Tools
Tools from manufacturers aren't always great, but you appreciate them more after you've tried to use a microcontroller that doesn't have any such tools available...
Step 6: The $100 Paradox
have bought your way into an interesting realm of "bang for buck."
"About" $100 will buy:
- Relatively fancy development board for most micros; covering a wide range of processors and performances (including PC compatibles, for instance.)
- brand new Low end palmtop (ie Palm Z22)
- used last-generation desktop system (go two generations old and you can probably get a display too.)
It WON'T buy much in the way of custom development, if you're paying for it.
Now a palmtop makes a lousy motor controller. But if you "need" the color display and touchscreen, it might be easier (and cheaper) to add motor control electronics to a palmtop than it is to add a display to a bare microcontroller. Especially since the palmtop comes with a development environment for making the display DO things...
Step 7: Microchip PIC Microcontrollers
Architecture: harvard, accumulator based (mostly)
Package sizes: 6, 8, 14, 18, 20, 28, 40, ... 100
Program memory size: 256 words (12bit words = one instruction) to 256k bytes (2 bytes=1 instruction)
Data RAM: 16 to ~3900 bytes (4096 byte address space, shared with peripheral registers.)
Special features: EEPROM, 20mA output drive, several "sub-architectures"
Flash memory based PIC microcontrollers curently range from vanishingly small 6-pin chips in SOT23 packages to 100pin TQFPs. The basic architecture has been extended to chips with 16bit ALUs and integral DSP functionality.
Microchip has a liberal sample policy and chips are widely available from many vendors.
Step 8: Resources for Microchip PIC
- Microchip the Manufacturer
- PICList mailing list repository of knowlege
- [http://techtrain.microchip.com/masters2004/(kgmnvafutocq2355egt11231)/downloads/classlist.htm Microchip Masters Conference 2004 Downloads] Tutorials and presentations
- [http://techtrain.microchip.com/masters2005/(kgmnvafutocq2355egt11231)/downloads/classlist.htm Microchip Masters Conference 2005 Downloads] Tutorials and presentations
- Starting with PICmicro Controllers Tutorial
- PIC Elmer 160 Another Tutorial
- WinPicProg Tutorial Tutorial w hardware designs.
- PIC vs. AVR smackdown A comparison between PIC and AVR
Intro to PIC Microcontrollers
PIC micro Timer Code
"TouchTimer" EggLight
Business Card PIC Programmer
Buildng the Inchworm ICD2 PIC Programmer / Debugger
Other PIC Instructables
...Collaborators feel free to extend this page here...
Step 9: Atmel AVR
Architecture: harvard, GP register based (mostly)
Package sizes: 8, 14, 20, 28, 40, ... 100
Program memory size: 1k byte to 256k bytes (2 bytes=1 instruction)
Data RAM: 32 to 8k+32 (32 bytes of gp registers, 0 to 8k of RAM)
Step 10: Resources for Atmel AVR
- Atmel the Manufacturer
- AVR Freaks Despite the amateurish name, this is a REALLY good site.
- AVR Butterfly The AVR "Butterfly" evaluation board is a phenomenal value at the current price of $20.
- Another Butterfly vendor
- GCC and WinAVR
- Arduino is a sort of combination of some standardized hardware based on the ATmega8 or ATmega168 and a simplified development environment that hides some of the complexities of using gcc for AVRs. See also under "modules."
- Official Atmel Product Guide
- Device list at AVR Freaks
- Atmel AVR MCU Comparison Table Non-official table contributed by skylen
Getting started with AVR microprocessors on the cheap
Programmable LED
Synchronizing Fireflies
Other AVR Instructables
...Collaborators feel free to add additional information here...
Step 11: Intel 8051 and variants
Step 12: Resources for 8051
- 8052.com site Massive amounts of info.
- Atmel 8051s Atmel does 8051s as well as AVR and ARM
- NXP (Philips) 8051 89LPC controllers.
- RAMTron micros 8051s with FRAM non-volatile memory
- Silicon Labs Neat 8051s including high performance ADCs. Also the smallest 8051; 11pins in a 3x3mm QFN. Cheap USB "toolstick" eval platforms.
Step 13: Freescale (Motorola) 68HC908, HCS08
The Freescale xx08 microcontrollers are one of the few microcontrollers with a genuine von Neuman architecture. Peripherals, Flash, and RAM all share the same 64k address space.
Step 14: Texas Instrument MSP430 micropower Microcontrollers
The MSP430 is one of the few natively 16-bit architetcures in the microcontroller world.
- There's currently a rather cool $20 USB stick development system offered: eZ430-F2013
- TI's MSP430 Overview page They have free online training, too. Every year about the beginning of may (4/30, get it?) they have a free seminar given at various locations around the country. Usually this includes a giveaway (last year it was one of the eZ430 things.) Worthwhile.
- Trip report to an Early TI seminar Describes 430 basics (by me)
- MSP430 Application Reports Nice document by Lutz Bierl
- MSP430 Yahoo Group pretty good forum.
Step 15: ARM microcontrollers
Recently, some of the manufacturers of ARM architecture chips have started offering combinations of on-chip memory and peripherals, and price, that put them into the same marketplace with 8 and 16bit microcontrollers. If you're likely to need lots of memory and performance, it may be worth looking at ARM chips. Or maybe even if you're NOT. As a professional, the possibility of having a single architecture that spans from 28pin microcontrollers to 400MHz router CPUs is attractive in many ways.
Currently, I'm finding that the breadth of the ARM space seems to generate some confusion. Putting together a tool set and development environment for a particular ARM chip can be challenging.
- [Http://www.arm.com ARM the company]
- Luminary Stellaris $1 ARMs with as few as 28 pins
- NXP (philips) LPC ARM controllers down to 48 pins and $3.
- Atmel ARM chips Atmel does ARMs as well as AVRs and 8051s
- ST M32 Cortex M3 chips Cheap chips with good peripherals, and Cute "primer" development system
- Olimex ARM development boards for Atmel, NXP, and other small ARMs
- GNUARM Homepage for the GNU ARM toolchain
- Instuctable: Pixecuter - Run Software on Matell JuiceBox
Step 17: Modules, bootloaders, and "hidden" microcontrollers
Parallax: home of the Basic Stamp
Basic Micro "ATOM"
BASIC Tiger
SunSpot Java thing
Modules/IDEs with ethernet/etc
Arduino: open source hardware and IDE for Atmel AVR
Another disadvantage is WRT the education aspect. You won't learn much about "microcontrollers" by programming a module in a HLL that hides ALL the microcontroller details.
Step 18: Zilog Z8 and Z80 chips
Fritzk9 said in comments:
Most of the people who have commented list the PIC, PICAxe, ARM, 8052, or Basic Stamps. These are all popular chips, but if you are just getting started with microcontrollers, you might want to start with something fairly cheap. How does $40 sound?
That's what the Zilog Z8 Encore! 8-bit microcontroller development kit costs. The Z8 Encore! microcontrollers are available with 1K to 64K of flash RAM. For speed, they operate at 5- to 20-MHz, and depending on the chip, they are available in various packages from 8 to 80 pins. The $39.95 development kit contains a development board with input/output pins, a wall wart power supply, computer cable (USB or serial to connect your computer to the development board), and a free C compiler and assembler that runs under Windows. You don't need to buy or build a programmer, since you can program the chip right in the circuit you've built -- without having to remove it and reprogram it in a programmer.
All the Encore! chips can communicate serially through a UART (some have 2 UARTs). Some have analog-to-digital converters built-in, and some have an infra-red (IRDA) communications port. Oh, and there are up to 4 built-in timers on the chip, depending on the chip version. The price of an Encore! microcontroller is pretty reasonable, given all the capabilities (anywhere from $3 to $13 each from Digi-Key).
The C compiler is excellent. The Zilog C compiler has most of the capabilities of "big boy" compilers, like a floating point library, trig functions, etc. It produces better assembly code than I can, so I use it almost exclusively.
Remember that almost any non-trivial code you write will have bugs. The debugger supplied with the development kit permits you to step through your code and look at the results of variables stored in the various registers to help you locate your mistakes.
Digi-Key stocks two different Encore! development kits (either one costs $39.95); one for 8K/4K chips, and the other for 16K through 64K chips. The Digi-Key part number for the 8K/4K development kit is 269-3183-ND, and the part number for the 64K development kit is 2693249-ND. http://www.digikey.com
Zilog's website has a large number of sample applications, full documentation of their microcontrollers, and free updates to the C compiler supplied with the development kit.
I'd say that the only downside is that the Z8 Encore! isn't as popular as the PIC as a hobbyist chip, so there haven't been any books or many of projects published for it except for some articles in Circuit Cellar magazine. Oh, and if you are interested in microcontrollers, Circuit Cellar and Nuts & Volts magazines are two that cover the subject. Both are available at Barnes & Noble bookstores -- maybe Borders too. Or, just go directly to their websites:
Circuit Cellar Magazine
Nuts & Volts Magazine
Step 19: Win Valuable Prizes
- PRIZES. Some of the contests have significant cash prizes. $5-10k, which is not to be sneezed at.
- Winning even a minor prize (or being published) will look good on your resume.
- Frequently the contests are accompanied by "special offers" in the form of low cost development tools or free samples.
- Motivation!
- A contest may generate at least temporary interest and discussion on some processor of interest.
- The end of the contest usually includes publishing some or all of the entered designs, serving as useful examples for everyone else.
Usually there is nothing in the rules that prevents the entry from also being (say) your college senior design project. Alas, many contests are restricted to people over 18, and completing an entry in the timeframe usually allowed is not so easy as it sounds before you've tried it.
Currently running:
Freescale Low-end x08 "Black Widow" Contest half-price development kit on completion of 2 parts of the 4-part contest. $10k+ prize.
PICList Free PCB Contest Free olimex-fabbed PCB for your design. Small prize, small contest; runs every month! Must be PIC or SX based.
General reference for a lot of contests (includes past winners, etc.):
Circuit Cellar Magazine Contest Page
I entered Freescale's recent "Black Widow" contest for designs based on their very small 8-bit microcontrollers, which had a top prize of $10000 cash plus a trip to their design conference (and $1000 for each of 10 finalists to aid in completing a prototype.) I didn't make the finals :-(
However, I netted a T-shirt, a coupon good for $15 off a (low cost) development system, and oneof some ROOMBA robot vacuum cleaners raffled off to "early entrants." And I learned some stuff, too. That's not a bad haul. The contest apparently had 775 participants at the final phase...
Step 20: Try it Online: Virtual Labs
They have several Freescale, Luminary, Renesas, and TI development systems available.
Step 21: Free Stuff!
The way "free samples" work is that the manufacturer will happily send you several samples of a part, in the hopes that you'll try them out and be so impressed that you'll used them in a project that nets them sales of millions of units. Or (if you're a student) that they'll win some loyalty and "mindshare" when you get out into the real world and be more likely to use their microcontrollers than someone else's. Or that you'll write some magazine or web article that will call attention to their products. It's a marketing expense, and it's probably cheaper than many marketing expenses...
Microchip, Freescale, and TI all have very liberal sample policies. Look up a part on their website, and it's likely to have a "sample" button somewhere on the page; send them some info and in a week or so you're likely to have chips in hand. Other vendors are harder; you may have to talk to a representative. Vendors have a weak spot (as they should) for students; you might think that a sample request from a "my-u.edu" email address carries less weight than one from "nonexistantcompany.com", but that's not necessarilly true.
Ethics of Free Sampling
I suppose there are ethics to requesting free samples. Here are some of my personal rules:1) NEVER resell samples. I see lots of eBay listings for chips in quantities that match the max sample quantities of some vendors. It pisses me off. (Of course, this COULD be another "sample channel" officially endorsed by the vendor. But it doesn't look that way.)
2) Don't lie more than necessary. I think making up a company name is fine, but inventing 10000 fellow employees and a product that will sell 10k/year of a chip is over the line. (This has been especially interesting as I've transitions from student to engineer at unknown company to engineer at extemely well-known company. These days If I ask for a sample, I'm likely to get a phone call from an enthusiastic salesperson hoping for a win in our next big product, and I usually explain that no, the best they can hope for from me is to get inserted into some odd piece of custom lab gear.)
3) Don't be greedy. Some vendors limit you to so many samples per month, or per order. That doesn't mean you should submit new sample orders every month, or order the maximum number of samples allowed. (OTOH, be aware that for many of the chips we're talking about, the order processing and shipping costs more than the chips themselves...)
4) Spread Good Publicity. If you pubish a project that used a sample, be sure to say nice things about their product. If you can't find something nice to say about a chip you sampled, you probably shouldn't say anything at all. ("Don't look a gift horse in the mouth"?)
Visit Our Store »
Go Pro Today »
I've tried to diagnose the problem, but their help desk is no help and by this time (2012) they haven't updated most of their line. It is sad, because a lot of the chips actually have fairly nice features (high drive IO pins, to name one that is hard to find, and a good amount of timers, something I've only seen on SiLabs 8051s) but are impossible to use off of the development boards.
If anyone has solved these problems... I've got some ZNEO motor control µCs laying around I still want to use. Help!
You could also add http://maxim-ic.com to the free sample list, they have some nice things like DS80C390 and DS80C400 :)
http://my.opera.com/CrazyTerabyte/blog/2011/09/08/comparison-between-microchip-pic-and-atmel-avr-microcontrollers
I hope it's useful for other people as well.
TL;DR: In my opinion, AVR is better than PIC.
i've been using PIC AVR Zilog and now Rabbit
Regards,
Dave T.
ATmega8535 | ATmega16 | ATmega32 | AVR USB ISP Seller
FYI - this link is broken: "Trip report to an Early TI seminar"
Double Plus Good.
You will be missed T_T
Step 10.
You could look at the modules that claim to run JAVA or JAVA-like programs, for example: http://www.systronix.com/store/tini.html
Or linux/android Single-board computers (Beagleboard ?)
Or even a conventional laptop or DC-powered PC-class machine, perhaps with things like Arduinos to use for real-world interfacing...
Anyway: that link isn't bad, it's just (now) an empty page (with a referral to a relevant page at Atmel.) There are hints that it might come back, so I want to leave the link here alone...
Before the Arduino, these things were black boxes, and while I had an interest in electronics I had nearly zero working knowledge. Now I feel relatively confident that I could read some reference material on an Atmel chip and work out how to utilize it in a project without the Arduino platform. Other brands would likely take a little more work getting used to the differences, but it now definitely feels within my reach, whereas before I didn't even think such a thing was possible.
That's the power of boards like the Arduino and other hobby boards - they abstract away the nitty gritty, but it's only one layer of abstraction, so that learning the nitty gritty isn't a huge leap if that's what you want to do. I'm pretty sure that's what I'm going to do, but like I said I've only been into it for about a week so far. Even without learning the absolute bare metal workings of the chips, though, the Arduino and others can do anything their respective chips can do, you're simply locked in to certain chips lines.
The hobby boards allow you to play with microcontrollers without making you start from scratch, which is a significant barrier to entry. It makes microcontrollers significantly less accessible. Plus, while the brand-name boards may be $30+, you can easily find kits for less than $15, and if you move certain functionality off board (like the USB or Serial connection) you can drop it down to below $10 - about what you'd spend to use the same micro-controller without the platform. And once you know how the board works, incorporating it directly into a project board is no problem at all and does not cost much, if any, more than it would to use the microcontroller directly. At that point you're only paying for parts.
You've helped my decision alot, as I was using AVRs from Atmel, and was experimenting with Arduino, but was thinking of switching to (or expanding to) Pic, as it is far-wider spread, and more comprehensively documented, and you guide re-affirmed this for me.
As I type this, I've ordered a Pic starter kit, including some Pic chips of various sizes, a programmer, and a book detailing some simple, beginner-level circuits. Thank you very much for this extremely well-written instructable!
Bravo!
Excellent Job.
