Step 15ARM microcontrollers
Recently, some of the manufacturers of ARM architecture chips have started offering combinations of on-chip memory and peripherals, and price, that put them into the same marketplace with 8 and 16bit microcontrollers. If you're likely to need lots of memory and performance, it may be worth looking at ARM chips. Or maybe even if you're NOT. As a professional, the possibility of having a single architecture that spans from 28pin microcontrollers to 400MHz router CPUs is attractive in many ways.
Currently, I'm finding that the breadth of the ARM space seems to generate some confusion. Putting together a tool set and development environment for a particular ARM chip can be challenging.
- [Http://www.arm.com ARM the company]
- Luminary Stellaris $1 ARMs with as few as 28 pins
- NXP (philips) LPC ARM controllers down to 48 pins and $3.
- Atmel ARM chips Atmel does ARMs as well as AVRs and 8051s
- ST M32 Cortex M3 chips Cheap chips with good peripherals, and Cute "primer" development system
- Olimex ARM development boards for Atmel, NXP, and other small ARMs
- GNUARM Homepage for the GNU ARM toolchain
- Instuctable: Pixecuter - Run Software on Matell JuiceBox
comments
Add Comment
Add Comment
