Step 3Cleaning the inside.
Now, put on your gloves if you don't want to get scraped up. If you do want to get scraped up, don't bother.
Dump out what you can.
Now grab your taxidermy scraper and your melon baller, which should be sufficient in scraping out all of the stuck-on matter from a typical gourd, and start scraping. And scraping. Scrape out every last bit of fiber, dust and seeds, dumping the mess into the garbage as you go, or vacuuming it out with a shop vac (recommended). If there are areas in your gourd that are tricky to reach, try using a power drill with a wire brush bit around those bends. You can also try bending long-handled spoons to reach odd areas, but it's not very effective in most cases. At this point you may end up with a very clean vessel, and if that's the case you're lucky.
A lot of gourds, though, have stuff inside that resembles thick, squishy styrofoam, and it's very difficult to scrape out. In this case you may want to resort to soaking. Set your gourd in a sink or tub, open side up, and fill it to the top with very hot water. Let it soak for a half hour or so, and when the water is cool enough you can stick your hand in there and start peeling that foamy stuff out. Whatever is left after peeling you can now scrape out with your melon baller or taxidermy scraper. You'll need to let the inside dry out before moving to the next step: sanding.
If you want the inside walls to be smooth you'll need to sand them. You may have a little piece of "stem" (umbilical cord? LOL) in the bottom of the gourd. You may ant to remove it with pliers, as not to scrape your hand on it while sanding. Use a sanding sponge, which easily adapts to the curves, to rub the walls smooth. You can then wipe or vacuum it out, and your gourd is ready for whatever project you have in mind.
Have fun. I'd love to see your finished projects if you'd link to them in the comments :)
Haven't ever tried gourd craft, so a real nubie question: How did you cut it open?
