3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to clean a toilet without chemicals
It's not hard, in fact it takes less time and you end up with a sparkly clean toilet...
If you do this once a week you'll never need to use bleach or limescale remover...
Step 1You will need.
You will need.
- A dirty toilet, I waited for ages to get mine this dirty, used it as an ashtray and let it get dirty...
- A plastic toilet brush
- One square of toilet paper
That's it, note the lack of 'products'
31 comments
Jun 17, 2008. 9:03 PMRishnai says:
At first one wouldn't think that dirt gets into the emamel, but it's true. The toilet that came with this house has an absolutely spectacular mold problem. I've never been able to keep mold out of the toilet for more than a week, even when I unbolted it and suspended it upside down submerged in a large basin of bleach.... I think I need a new toilet.
Jun 3, 2011. 1:54 PMcrazycloud says:
Vinegar kills mold too.
May 2, 2008. 5:20 AMtfaulk26 says:
1. Depending on the design of a brush and frequency of cleaning, you may actually not need any toilet paper and just use the brush, thereby doing even more favor to the environment :) 2. Now with lime/scale remover: this method is for cleaning only and doesn't substitute lime/scale removal, because you are dealing with chemistry here: if your water is hard, lime and scale will precipitate on your plumbing fixtures AND INSIDE THE PIPES, - no matter how thoroughly you clean the bowl, - so you need to deal with lime/scale removal separately. Overall, good instructable to show that we can go easy on buying household cleaning products.
Jun 6, 2008. 6:21 AMlaurel1 says:
Vinegar (a lot cheaper and nontoxic) will do the same thing in a steam iron, kettle, etc.. I soak ice cube trays in it,too. Vinegar will also soak off the burned food, like spaghetti sauce, out of a pot. Don't bury them in the backyard like my grandmother used to do. Oh yes she did! The water here makes a limescale ring in the toilet bowl. Anyone have an organic solution for this?
Dec 23, 2010. 5:50 AMmguer133 says:
I just wrote the same comment earlier on :
"white vinegar. Leave 1/2 cup full in the toilet bowl overnight. Scrub a little bit the next morning.
You can clean pretty much everything around the house with white vinegar. It's natural, cheap and not toxic.
You can even use it in your washing machine, your dishwasher etc.
In addition to baking powder or other comment products, you can make any cleaning product naturally."
I guess the water in your area is very hard. Maybe a magnet around the input pipe such as this explains (I have no interest in that firm, I just googled it) :
http://www.whatswateringyou.com/MagneticWaterSoftener.htm
Jul 23, 2008. 7:45 PMPompom says:
Thanks for the Instructable, and I'm glad there's decent comments, but, I don't think I can successfully clean my toilet with just one piece of toilet paper... Any suggestions for a narsty tank? Like solid grime yuckiness? I've tried emptying the tank as much as I could and using a toothbrush to get stuff, but there's only so much of that I can handle, and it seems to be a never ending battle. It also seems as though the enamel deep down the hole of the bowl (the siphon?) has worn away to be black. Or maybe it's bad buildup? I can scrub forever and it seems to remain. We have hard water.
Feb 26, 2009. 5:57 AMbelsey says:
Borax! Just 1/4 cup overnight (or for 20 minute). Cheap, easy, and works like a charm.
Dec 23, 2010. 5:38 AMmguer133 says:
Apr 25, 2010. 4:55 PMginamarina says:
could you teach my SO how to do that? LOL. He doesn't seem to understand why that brush is there.......  or why the black light for finding cat pee makes the toilet area look like a crime scene...  o.0
Oct 14, 2010. 10:12 PMchris76108 says:
ROFLMAO!!!!!!!!!!!!!!!!!!
Then she would have pee on the ceiling and all over the walls as he spazzzed out! LOL!
Jul 1, 2008. 8:18 PMDJ Radio says:
Aren't you supposed to empty the tank first before you clean?
Sep 2, 2009. 1:34 PMGamernotnerd says:
Or you could just turn the supply off and flush, if you have the valve, that is.
May 2, 2008. 6:31 AMdchall8 says:
Just an observation: your toilet does not seem to be holding enough water in the bowl. Your water level sits down in the trapway. The water level should be high enough to flare out into the bowl above the entry to the trapway. Are you sure it is plumbed right inside the tank? Some of the refill water should be flowing into the overflow pipe. Now...more than you wanted to know about toilets: I work from a hotel room most of the time so I've seen quite a bit of change in this arena. When the low flow requirement first came on the market the manufacturers thought they could get away with keeping the same size tanks but with interior dams and a changed flapper design. Then they made the bowls steeper with a smaller diameter trapway. That was a miserable failure requiring multiple flushes and wasting more water than it saved. Now they have worked out the design details to make low flow toilets work. The solution to the problem turned out to be in the hands of real rocket scientists. No wonder standard plumber technologists didn't get it right at first. The solution was to increase the diameter of the trapway from 2 inches to 3 and even 4 inches. They also increased the diameter of the flush valve, glazed the interior of the entire trapway, and smoothed out the kinks in the trapway flow path. I promise you would be amazed to see a Toto Drake, American Standard Cadet 3, or a Kohler Cimmaron toilet flush. No more swirling water for 15 seconds. Now it simply disappears, almost silently, in 2 seconds. Now back to the point of this Instructable. American Standard's Cadet 3 model comes with a special glaze that resists the growth of bacteria and fungi. It works very well. The more expensive Toto Drake has a similar glaze on a few of their designs - generally not the model you want. If you pursue this, American Standard makes a model called the Cadet. It is junk. The Cadet "3" is the one you want.
Jan 24, 2009. 1:15 PMJames32145 says:
"Just an observation: your toilet does not seem to be holding enough water in the bowl. Your water level sits down in the trapway. The water level should be high enough to flare out into the bowl above the entry to the trapway. Are you sure it is plumbed right inside the tank? Some of the refill water should be flowing into the overflow pipe." There is nothing wrong with the toilet pictured. It is called a washdown toilet, which is found all over the world except America. They push the waste down and out with a high flow of water, as opposed to filling the bowl and syphoning it out. This allows for the lower water level. They are also less prone to blockages and more effective at flushing and carrying waste further down the line as water is pushed down after the waste, not before it.
May 2, 2008. 7:05 PMMr. Rig It says:
Wow a toilet nerd, :)
May 2, 2008. 8:51 PMdchall8 says:
Scary, huh.
May 2, 2008. 9:11 PMMr. Rig It says:
lol
Jun 11, 2008. 9:56 AMLithium Rain says:
An ounce of prevention is worth a pound of cure...:) One thing, if I may. Antibacterial soaps can lead to the breeding of supergerms. While I agree on using it after this particular ible, maybe you should use regular soap and water for regular hand washing. Other than that, nicely done.
May 29, 2008. 5:31 PMSir-Jackington says:
I will be having nightmares about what is in that toilet
May 29, 2008. 5:43 PMSir-Jackington says:
NEVER!
May 1, 2008. 9:33 PMLinuxH4x0r says:
well.... that was informative
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
197
Author:killerjackalope(My website)
A northern ireland based maker that likes breaking stuff as well as fixing it, of no fixed abode for now Working PR for a club in Belfast and freelance photography. I enjoy working with computers,...
more »
