How to clean and re-wax a surfboard by kinawera
Featured
What's the matter? Got sand in your wax?
The main problem with surfing, apart from the fact that it is almost impossible, is that you get sand in your wax, which turns your board into a manually operated belt sander, especially as you duck dive under waves. This is not such a problem in cold places, because you wear a nice long wetsuit. But in warmer spots, your legs/knees with soon resemble a raw souvlaki column. This instructable tells you how to clean the old wax off, and put new stuff on!
Step 1: Start with clean board
This board has just been cleaned. There are a number of different ways you can clean the old wax off, but the best way, I think, is to leave it in the sun to let the wax soften, then scrape off with a board scraper (that I lost) or your driver's license (that I haven't lost). The license works better. You can remove the last of the wax by rubbing the board with a rag soaked in turps (turpentine). I've heard that Vaseline also works well for removing wax, but it's not as instant as turps and the fumes don't make you giggle as much as turps.
Finker says: Jul 16, 2010. 10:02 AM
By the way, nice board.
Finker says: Jul 16, 2010. 10:01 AM
Ah, thanks this is going to help me so much.I always hate sand in my wax.
jc253627 says: Apr 29, 2010. 5:10 PM
Really the quickest way to remove old sandy wax is to take a pot of boiling water and just slowly pour it over your board with one side up so the wax runs off the down side. The wax jumps off the board and leaves it shinny clean in about 1 minute, best part, no scraping. I then dry it and do like mentioned above, wax in the microwave, (I make my own by mixing a really sticky soft cold water wax with grocery store paraffin wax which is really cheap. Play around with it until you find the right mix for your area and season and you'll save a lot of money on wax and still have a high quality wax that is tailor suited for you and your area.
msean says: Apr 18, 2010. 9:43 AM
If you turn your board on its rail when you're letting the sun melt it, most of the wax will just run down the board, saving you some scraping.
benthekahn says: Jun 10, 2008. 9:21 PM
I did this similarly to my skimboard a while ago. As you can imagine, skimboards get even more sand in them. It only took about 5 minutes in the sun for the wax to soften.
dudejetfighter says: Jul 9, 2009. 7:57 PM
hey a little tip when your not skimming drop your board upside down it helps allot
Chard says: Aug 15, 2008. 1:14 AM
add this to my new group Surfer's Paradise!
NeilLizard says: Mar 2, 2008. 4:05 PM
Leaving your board in the sun is not very good for it. Also, when I wax my board I just heat up the wax in the microwave then spread the liquid wax on the board. Great instructable by the way
MerleCorey says: Jun 10, 2008. 9:02 PM
nah its fine for a few minutes, i mean your in the sun when your surfing anyway right? and who wants a white perfect board any way, i find that out of my 11 boards the newest sticks get wet the least. But mabey its cause i don wanna mess them up. Anywho....ahem...I think every one leaves their board in the sun to remove wax right? Yellow up that thing man go on ahead. and then put some nice dings in it and fix it with cheaper resin that turns yellow anyway. Muahah aha ha
GorillazMiko says: Feb 25, 2008. 3:50 PM
Hate it when sand gets in the wax... doesn't it just GRIND YOUR GEARS?!? Awesome Instructable, could help out a lop of people that get mad because of the same problem.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
