I would recommend watching the youtube video before reading the rest of this instructable.
Remove these ads by
Signing UpStep 1Materials
There are a few materials needed because this instructable is rather an easy one. However every material is important. The pictures below show most of the materials.
2 vacuums (preferably handheld or canister because they are light)
2 tubes that can fit from a vacuum to a vacuum glove
6 by 1/2 screws with washers
2 pieces of wood, the larger the area, the more weight it can hold( but be careful, the wood can get very heavy )
rubber to fit around the piece of wood
2 handles
tape
Most of the materials can be found at Lowes.
Getting it off the wall is rather easy, turn the vacuum off.
So if you want to climb walls you should make two of these and put the power buttons of each vacuum on the wood itself. That way you can turn it on and off with your hand.
so climbing would go like, attatch one to the wall by putput it a little higher. then the second one and so on....
Michel
