loading
Step 4: Connect the vacuum to the vacuum glove
            All that you have to do now is to connect the tube to the hole that you made in the vacuum glove and to the vacuum. You can tape the outside of the vacuum glove hole to the tube so that it is airtight.
Whats Size of the plywood
How do u connect the pipe to the vacuum
<p>How much watt vacuum cleaner needed for this?</p>
thats not how to climb up wallls i wall walk its eeasier
wall walk??????????????
sorta u have two walls ok make sure u can put ur feet on them and thats how i do it
oh yeah i have done that before, this only uses one wall
u can be ninga and use one waal no tools<br>
would you think some thin plexi-glass would work? I would bet it would be lighter, and wouldn't really wear too much
it should work
Is that rubber pipe insulation.
There really is no extra insulation you need to put anywhere. The &quot;rubber pipe&quot; I think you are looking at is just tubing that connects the vacuum to the vacuum glove.
No I mean the rubber on the bottom so it will not slide down the wal
Yes, the bottom of it is pipe insulation. Sorry. I just went to the store and grabed it without knowing .
whatd you use for the rubber it looks like bike inner tube
The rubber is for friction. You can use a bike wheel, but it may be more expensive than the rubber I used that was $3.
what rubber did you use?
Sorry it took sooooooo long. The rubber was pipe insulation. It isn't the best rubber because it isn't really rubber. There are a lot better options. I just wanted to go for the cheapest.
how do you climb? i mean, how do you get it out of the wall and stick it again?
Climbing is something you would do when you have two vacuums.<br> <br> Getting it off the wall is rather easy, turn the vacuum off.<br> <br> So if you want to climb walls you should make two of these and put the power buttons of each vacuum on the wood itself. That way you can turn it on and off with your hand.<br> <br> so climbing would go like, attatch one to the wall by putput it a little higher. then the second one and so on....<br> <br> Michel<br>
Lol , much simplest : just make a hole on the wood and insect a air Switch . Switch ON= no suction Switch OFF = Suction
Awesome idea
yeah that's what i thought, thanks mate
Your welcome :)
Exactly what MichelMoermans said. These vacuums were my grandmas so I didn't want to take the power switch off and extend it. If they would have been my own vacuums, I would extend the switch and wrap it around around the tubing. Then screw the power switch from each vacuum to each vacuum glove, right next to the handle. Thanks for the question!
very cool instructable!!!!!!!!!!&nbsp;:)<br />
Thanks!!!
awsome!!!!&nbsp; i am 12 too!&nbsp; i am very impressed,! 5 *'s faved and subbed!
Not at all what I was expecting, but very cool.<br />
About This Instructable
9,397views
21favorites
License:
Bio: I love knex, airsoft, making weapons out of anything, annoying my sister, paintball, FOOTBALL (BEST GAME EVER), all sports, and breakdancing. my pictures 1 lightning ... More »
More by Football viking boy:Trebuchet knex sling gun New removable mag idea
Add instructable to:
