loading
Step 2: Under-over coiling
For thicker wires you need to use under over coiling. This keeps the wire strait in its coil so twists cannot dammage the wire. You should use this for wire with more then one plug on the end, like looms. (I did not have a loom at the time so I have used a piece of rope instead)
Also, you will want to do under-over coiling on the floor if you have a large, delicate wire/loom. Begin with a normal twist loop to make a circle (make this as large as possible because tight coiling is not very good for the wire) Then you need to make a twist in the opposite direction and bring your hand behind the uppermost piece of wire. The image should make this more simple. Then do another normal coil and continue like this, normal, UO, normal, UO and so on. With large cables like looms secure the coil with PVC/electrical tape.
About This Instructable
7,594views
5favorites
License:
Bio: The name "Ikkalebob" was invented by my cat when she ran across the keyboard. I attempt all manner of projects, from home engineering to prop ... More »
More by Ikkalebob:Smartphone Controlled Cat Laser The Witcher 3 Full-Scale Chort/Fiend Sculpture in DAS clay Cold Metal Casting and Patina on Skyrim Dragon Priest Masks
Add instructable to:
