How to configure uTorrent for maximum upload and download speed.
Step 9Maintaining high speed peers/seeds list
This is an additional tip I'm inserting which I often use but forgot to mention originally.
Many times, the reason for torrents suddenly slowing down is because a high speed peer or seed went offline and the other ones aren't uploading as fast. In this case, you can't do anything, since it isn't possible to force those people to start seeding lol
Another scenario is that those peers are still seeding, but you have lost connection with them (which could happen due to a number of reasons) In this case, it is useful to save the IP address of these high speed peers so that you can connect to them later on. To save the IP address of a specific high-speed peer:
1) Go into the "Peers" tab
2) Observe the list of peers, focus, in specific, on the "down speed" column, this shows you how fast you are downloading data from that specific peer/seed.
3) Right-click on the peers which are giving you faster speeds
4) Click on the "Copy selected hosts" option
5) Open up Notepad and paste using Edit --> Paste or press Ctrl + V
You'll notice that the number appearing will be something like this:
xxx.xxx.xxx.xxx:xxxxx
The bit after the colon shows the port which that specific peer is using to connect. You may copy the addresses of multiple hosts and save it somewhere on your computer
When your download speed has decreased and you want to try to connect to these peers:
2) Right-click on an empty portion of the space below
3) Click on the "Add peer" option.
4) Copy and paste the IP address and port no. of the high-speed peer (paste it as it is, don't make any modifications to it)
5) Click on OK
6) If this does cause an increase in your speed, then it means you have connected to that peer and have started downloading. If your speed doesn't change, it means that you failed to connect to that peer, mostly because it is offline and not seeding anymore.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Ali_Athar
