How to Control Your (GUI Mode) Raspberry Pi 2 With Ethernet From Windows PC
1,685
40
Posted in TechnologyRaspberry-pi
Introduction: How to Control Your (GUI Mode) Raspberry Pi 2 With Ethernet From Windows PC
Hi Guys
I am Pushkar Jog from Goa, India and I am gonna show you guys how to control your little credit-card sized powerful computer, Raspberry Pi without using extra monitor, keyboard and mouse but just with Ethernet
IF U HAVE ANY DOUGHTS REGARDING THIS INSTRUCTABLES THEN MAIL ME ON 'pushkarjog2001@gmail.com"
Step 1: Requirements
For this u wil require some temporary and some permanent accessories
Temporary accessories are
1) USB Keyboard and Mouse
2) HDMI Cable
Permanent accessories are
1) Raspberry Pi 2 model B
2) 5V 2A USB Adapter
3) USB cable (USB to micro-USB)
4) RJ45 (LAN/Ethernet) Cable
5) At least 4gb memory card with NOOBS or Raspbian installed (If you don't know how to do this, then have a look at https://www.raspberrypi.org/help/quick-start-guide... )
6) Windows PC (Windows 7/8/10)
Step 2: Installing XRDP on Raspberry Pi
For using GUI on RPi 2 we need to install an package called XRDP server
  • For installing that type the following in lx terminal :
sudo apt-get install xrdp
  • Wait for sometime and you will get it installed
Step 3: Finding Ur RPi`s IP Address
Join the RJ45 i.e.LAN or Ethernet cable to Network port of ur Pi and the other end of your cable to ur router/modem
Note : Ur PC should also be connected to the same router and the router should be configured with ur pc
To communicate with the RPi from Windows u wil need to know about ur RPi`s IP Address
  • To do this u need to enter the following command in ur Pi`s lxterminal :
ifconfig
  • U will get something like shown in pic
  • Select inet address (only numbers and dots) from the eth0 para (i dont know whether its a para or not..!!) and copy it (note it down)
Step 4: Final Configuration
Now come to your pc and search for Remote Desktop Connection in Start menu
open it
A menu will appear as shown in the pic above
  • Click option/show options
  • A bigger menu will appear as shown in the second pic
  • Enter ur Pi`s IP Address (that we earlier found out and noted) as the name of your computer
  • Enter ur user name (normally pi) as username
  • And deselect the Always Ask For Credentials check box
  • A window will appear with a menu in centre
  • Select module as Sesman-xvmc
  • Enter ur username
  • Enter ur RPi login password (Normally raspberry if not changed)
  • And click login
  • And there u go u r having full access to all the functions of your sweet little Pi
Step 5: After Setting Up (LOGIN NEXT TIME)
  • If u had deselected the Always ask for credentials check box as I told in previous step then u dont need to enter anything just enter ip and click connect
  • If not then u will have to perform the previous step once again and remember to deselect the checkbox
THANK YOU GUYS FOR WATCHING THIS INSTRUCTABLES
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    2 Comments
