3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to convert Real Audio streamings to MP3 files
Hello!
Probably some of you listen to audio contents or shows from web radios by Real Audio Player or Real Audio Plug-in of the web browser.
The PROBLEM
These files are often broadcasted as streaming, but usually it is not possible to download them for off-line listening.
The SOLUTION
In this instructable I explain how to download a Real Audio streaming and transform it into a MP3 file, suitable for listening on computers and MP3 players, or burning to audio CD.
IMPORTANT
Some of the software used in this instructable is in Italian language, so the menu and functions represented in the pictures may not correspond to your software. I hope this will not limit the understanding of the instructable.
Credits:
This instructable takes some useful information from the following sources:
- http://swen.antville.org/stories/735413/
on Swen's Weblog. Very detailed explanations and many tips there in.
- http://giubot.wordpress.com/2007/10/01/da-stream-real-a-file-mp3/#comment-963
on Giubot's Weblog. A short but clear explanation about alternative strategies for downloading and recording (in Italian).
Step 1Software
Software
I will propose three methods:
- First method, based on Flashget. This is the most direct procedure.
- Second method, based on Real7time. This is an alternative if the first method does not work
- Third method, based on Audacity. This is the final solution if the previous methods do not work.
Please notice that THE PROCEDURE AND THE SOFTWARE THAT I SUGGEST ARE NOT THE UNIQUE WAY to obtain MP3 from Real Audio streaming. Alternative software to accomplish the same task is available. Nevertheless the purpose of this instructable is just to explain a direct and simple procedure.
What is needed
For this instructable you need a Windows PC with and some additional software listed below.
This instructable uses Open Source software, FreeWare, and Free versions of commercial software.
- RealPlayer software or RealPlayer Plug-in. This is probably already installed if you use to listen to Real Audio streaming. Free version available.
http://italy.real.com/player/win/
- FlashGet, an efficient download manager
http://www.flashget.com/en/download.htm
- NCH Switch, free audio file converter
http://nch.com.au/switch/
The NCH audio suite is a commercial solution for handling and processing of audio files. A free version is available. Some of the tools of the free version expire after a while, but the Switch conversion tool does not expire.
- Real7time, recorder for audio e video streamings.
http://r7cproj.euro.ru/indexe.htm
Audacity, a great open-source software to record and modify sounds
http://audacity.sourceforge.net/download/
2 comments
Jan 27, 2012. 3:26 AMtiouubem says:
if you use directly a mp3 search engine you will not need to convert in the first place, would be an easy way around.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:isacco
