How to Convert a IKEA Jonisk Lamp With LEDs
Introduction: How to Convert a IKEA Jonisk Lamp With LEDs
I bought a IKEA Jonisk lamp to have in my living room, but when i powered the lamp up with a 60W bulb it become hot as ****. I started to figure out how to convert it to a LED-lamp instead.
I found a company that sells high powered LED modules ( I ordered 3 SEOUL P5 RGB LED that already was mounted on a PCB. For controlling the LEDs I choose a PIC16F628A and 3 TLE4242G constant current sources. After that I found a remote controlling kit laying around in a box, so I added it to the project. By controlling the current sources with a uP and PWM, I now can blend the lamp to almost any color I want. And it use much less power now and generates almost no heat.
This project was not supposed to be on from the beginning so there is a lack of photos in the instructable.
Step 1: What You Need
1 IKEA Jonisk
3 Seoul P5 RGB on PCB
3 TLE4242G
1 PIC16F628A
1 LM78L05
some SMD resistors and capacitors
a PCB designed by my self and produced with your favorite method
a sheet of copper, 1mm thick
RXF-4303D and TXF-4311R remote control kit ( I had on laying in my box of spare parts :) )
Power supply 12V 1A
Thermal grease
PIC programmer ( PICkit 2 )
Wires, nuts.......
Step 2: Dismantle the Lamp
I started with the dismantling of the lamp to make some measurements for how much space I have in the lamp.
Step 3: Make the PCB
I use EagleCad for all my projects that needs a PCB.
The make the PCB with your favorite method, I use the toner transfer technique and Hydrochloric Acid + Hydrogen peroxide to etch the PCB.
Step 4: Make the Heat Sink
Because the 3 current sources and the 3 RGB LEDs make some heat I had to make a heat sink. I took a piece of cooper sheet and cut out a circle that is the same size as the PCB
Step 5: Start to Populate the PCB and Heat Sink
Start to populate the PCB with all the SMD components and visual inspect all your soldering. After that is complete, mount the PCB on the heat sink and mount the LEDs and all the hole mounted components.
Step 6: Make the Firmware
Use your favorite complier to make the firmware to the uP so it get the functionality you want. Program the uP and test so everything works.
Step 7: Assembling the Lamp.
When everything works you can start to assemble the lamp.
Step 8: Power It Up and Let It Shine
Connect the power supply to the lamp and turn it on with the remote control. I have programed the lamp so I can select different modes, like dim one color, cycle trough all colors, etc. I can change the speed of the change.
Step 9: Update!!! New Remote Receiver
I have finally made a new remote receiver. Now the lamp can be controlled by home power remote controllers, in Sweden they are branded NEXA, Now i have a wall-remote that turns the lamp on/off and select mode and a small remote to control the rest of the functions.
I will asap make a instructable how to make the new remote receiver.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Hi Lond, I too am somewhat confused. What is the difference between just using a standard LED "mood" bulb screwed into the original fixture, and the mod you are suggesting? Is the regular store-bought colored light not powerful enough? Or is it all about tweaking and modding yourself?
    I should add that I really LOVE the end result of what you did, but sadly I'm definitely not a DIY person, so most of what you are saying is a lot of mumbo jumbo to me (e.g. I have no clue what a PCB is). So if I can reach a similar result without using any tools, that would be great. Otherwise, perhaps you can explain it to me in layman's terms? And then I will have to call a friend... :)
    Thank you!
    you could just use an led light bulb
    Haven't found a led light bulb that are more powerful then my lamp.
    With white colour and no diffuser it's brighter then a 100W light bulb. And I like to create and modify things, so just to change the bulb wasn't fun enough.
    Thank you so much Lond. Now I finally opened it.
    I'm interested! How far did you get with the instructable? Tell us more...
    Great project!!
    ...but source code??
    The source code is constantly evolving, so when I learn something in a other project I update the source code for the lamp. The current code I use is for the updated lamp.
    Please don't take this as criticism, as I do in fact quite like your final product, but there is something terribly wrong about the statement "I update the source code for the lamp."
    LOVE it !
    i'm a big fan of the "as is" corner of Ikea & are often drawn to their light fittings (missing a base or shade etc) to reuse with other found objects...
    i find LED/electronic assemblage abit too confusing... *are they're ready-made LED light fittings available? (like a pendant fitting with bayonet holder that you add your own shade to etc)
