Step 11Finish Drywall / Stain Floor
To cover the seams, I used standard drywall tape. Don't forget to buy the spray on glue.
Given that this isn't a high traffic area, I bought some minimal drywall edging to cover the outside corners.
Home Depot recommended very fine 220 grit sandpaper to sand the drywall compound. Using a power sander made it like butter. After sanding down the drywall compound, I decided to add texture to the walls. This is not a necessary step, as 90% of the walls are hidden. However, I wanted to learn how to apply texture, so I figure this was a good opportunity. Each can of texture doesn't provide a whole lot of coverage, as I went through about three cans of the stuff to get a texture consistent with the rest of the house.
One bonus regarding texture: it hides drywall seams well. Once I had everything painted, most of my mistakes were well hidden.
After covering, sanding, and texturing everything, I thoroughly wiped down the walls before painting. Given that this will be a high humidity area, I used latex paint; the same stuff you'd use in kitchens or bathrooms. Of course, don't forget to prime first.
After letting the walls dry for a day, I stained the floor using an interior oil-based stain. Home Depot had one in a color call "Cabernet". It really stood out, which is what I wanted as I didn't want it to seem like I was trying to color match with my hardwood floors. One word of caution: it takes a bit more to stain something such a dark color. Double however much you think you're going to need.
I left everything dry for several days, which wasn't a problem as I only had time to work on this during the weekends. I also had "Cabernet" wood stain on my hands and arms for several days, so don't forget to invest in some latex gloves.
Add Comment
