3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to convert a closet into a mini wine cellar
Step 6Install Floor
Install Floor
I decided to install the floor next because I needed a foundation with which I could screw into. Since I couldn't mess up the existing hardwood floors, I built an elevated floor structure using 2x4s. Cross beams were set 16" apart.
Getting the already-assembled frame to fit into the closet was difficult, to say the least. I had measured the closet's dimensions before installing the vapor barrier, so with the barrier already installed, I lost a few precious centimeters. Getting the frame in required some brute force, which unfortunately also tore up the barrier a bit. I fixed it with some tape, but perhaps next time I would install the floor first, then hang the barrier.
Once I had the frame in, I cut up the fiberglass insulation and made a floor using 3/4" thick plywood. I didn't care so much about the quality of the hardwood given that I was going to stain the floor later. Creating the floor was just a matter of placing the insulation inside the frame and screwing the plywood to the frame.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:dedub01
