loading
Step 5: Removing the factory polarizing film
The next thing to do is to remove the polarizing film that is glued to the surface of the glass. The film is slightly smaller than the glass and can be seen easily if you look close up. I am using my scalpel to gently lift up the polarizing film a bit at a time. The trick is to slide the blade between the polarizing film and the glass.
Take your time and work from one edge of the polarizing film across to the other, slowly pushing the blade of your knife under more and more while still moving it from side to side. Eventually you will have the blade under far enough to lift off the polarizing film.
The film is stuck to the glass by a thin layer of tacky glue. It's pretty nasty stuff so be patient and it will come up eventually. Lift off the polarizing film using your plastic tweezers. You can see that the film looks almost transparent while over the display and the digits are only visible on the parts of the display that are covered by the film - it's quite amazing.
Here's where it gets very cool. Simply turn the polarizing film around 90 degrees and as if by magic the digital display becomes reversed! The polarizing film does not need to be in contact with the glass to work.
Hey bfgreen,<br><br>Thanks for this. I'm planning to do this soon. But I have two questions; Does this remove the &quot;Waterproof to 200m&quot; claim? Also, how does it look on backlight?<br><br>Anyone else who can help will be greatly appreciated.
<p>I use to have a negative display watch and the numbers were blue and when you turned the backlight on, they lit up bright blue, which made it very easy to see even in bright sun light, it was also a lot easier to see in sunlight without the backlight on, then the regular whitish gray or goldish displays. How do you convert the lcd, to show blue numbers? </p>
<p>Where can i get polarized film?</p>
‚ÄčIn the intro I give the name of the type of film you need or that I used and a hyperlink. http://www.polarization.com/polarshop/ (Look for a product called Linear Polarizer w/adhesive PFA). Hope that helps.
Thanks
<p>Hi bfgreen, how does the light work with the negative display? Will it still display the time clearly? Thanks for the guide.</p>
<p>awesome</p>
where did you get your new sheet of polarized material?
There is a link in the third paagraph, right at the tp of this instructable. I bought mine from <a href="http://www.polarization.com/shop/catalog/index.html" rel="nofollow">Polarization.com</a> in Texas. The quality was very good, service excellent, and the shipping was pretty fast (3 days). I ordered the thinnest self-adhesive film they had in a relatively small size, the part name was: <b>Linear Polarizer w/adhesive PFA</b>.
How was it sticking the new film on there? I'm going to get the same film as you did, thanks for the link, but I'm afraid of getting bubbles/fingerprints/dust under the film. <br> <br>Do you think I would have any problems/difficulties if I got the non adhesive version?
Oh and if you do screw up - I have myself - you just repeat the whole process :)
It takes some time to clean it thoroughly. You have to get ALL of the glue reside off and that usually takes me about 10 Q-tips and a lot of Goof Off (30 mins), but is well worth doing right. Keep it very clean and dust free, the slightest speck under the film will look horrible! <br> <br>IMHO you have to use the adhesive backing film, otherwise it could slide around a little. That's your call entirely, I've done this several times with sticky film and it's worked perfectly. Most recently I did a conversion of a Casio Frogman for a friend, it came out awesome! <br> <br>Take your time, do it carefully and you'll be ok. - BG
I wanted to do this back when I had my 95 corvette, since those have a LCD speedometer. My 2012 Chevy Sonic has an LCD speedo as well, doing this is pretty tempting, but also scary because I dont want to destroy anything from taking it apart. Warranty wont cover that part!
I have a dw6900-1v (not sure if the last bit was important) and i've heard that converting it to a negative display makes the numbers harder to see? And i have the same question as tcarr2 about the different colour negative displays!
now can you change the negative to a different color?
very nice..i wonder if this works with my riseman.
Yup, it'll work with your Riseman :)
thank you,i was about to buy a suunto only for the inverted screen:)
I recently converted my Casio G-Shock Mudman GW-9000A to a negative display. Here are the before and after photos.
You're welcome. There are a few models of Suuntos that I really like (<a href="http://www.suunto.com/us/en/products/Outdoor_Sports_Instruments/suunto-x-lander/suunto-x-lander-military" rel="nofollow">Suunto X-Lander Military</a>), but it blows my mind that none of the Sunnto watches are solar powered or atomically synced for accuracy. G-Shocks and Pathfinders have had these features for years. C'mon Sunnto make it happen!
Wow great instructable. I just did this to my new g-shock it was so simple i did it in about 10minutes.
Which model G-Shock did you do this too, just curious?
i dont remember the model lol got burnt in a car fire. and i just reversed the polarizing sheet that was already there
looks good, makes me want to go buy a watch just to black it out.
They're cheap at Walmart :)
I did this with my first LCD watch back in the 80s. Usually the polarizing material is on a diagonal; if that's the case, you don't need a new piece, just flip it over.
Yeah, probably - it's more an issue with the original piece getting mangled as you try and remove it that you end up needing a new piece :)
where would one go about getting new polarizing material?
In that particular case, the material was just sitting there, or maybe taped lightly in place. I suspect that newer watches are much more machine made, so the sticky-backed polarizers are probably standard now.
where to get this glass?&nbsp;
Glass? Do you mean the polarizing film? I bought mine from <a href="http://www.polarization.com/shop/catalog/index.html" rel="nofollow">Polarization.com</a> in Texas. The quality was very good, service excellent, and the shipping was pretty fast (3 days). I ordered the thinnest self-adhesive film they had in a relatively small size, the part name was: <b>Linear Polarizer w/adhesive PFA</b>.
BFGREEN,<br><br>Awesome... nothing to add about this. I hava a PRT 40C and i would like to turn it in a &quot;stealth&quot; mode. I have an ask:<br><br>Is totally necesary remove the factory polarizing film? Or I can just put the new one turned 90 degrees and it'll be in stealth mode?<br><br>Also i have a DW6700 Sky Force... i would like to mod it too, but it has a difference so has a bulb light non illuminator. Is possible to install a illuminator module to this watch?<br><br>Thanks for your time and best regards,<br><br>Juan Leython
Switching out the lighting module is far beyond my capabilities. There's an excellent G-Shock online forum as part of the Watch-U-Seek forums. Great folks who know just about everything about G-Shocks.
Juan, in my case I found that I had to remove the factory polarizing film because when I put a second layer on top it went 100% black, which was no good. If you can test it first then you might be able to avoid this step.<br><br>Let me know what you find out!<br><br>- Brian
cant you just flip the original screen over and it will work?
Not really, you have to remove it first and it's usually glued down. Removing it makes the pristine layer of glue look a real mess. Then you actually need to turn it 90 degrees, so if it's rectangular it's not going to fit. If you flip it over instead it wont make a difference because you won't be rotating the direction of the polarization.<br><br>If you want to try it be my guest. I've done this many times with Casio G-shock watches and not one of them would have worked or looked anywhere near decent if I had not used a new piece of film.
I think 3D TVs and projectors are based on this technology. 3D glasses are probably made with these kind of things. One side is set to view one polarity and other side is another for different reflection.
<br> I used to do this with cheap calculators (also Casio I think), and I even did it to an MP3-alarm clock I have, they look so much cooler with clear letters on a black background, I was lucky in that they had &quot;loose&quot; polarisers, so I just popped them out, flipped them over and popped them back in, and hey presto, a cool looking watch/clock/calculator/anythingLCDbased... :D<br> <br> Didn't have to do it to my current watch though, Casio got it right first time and put the polariser on the &quot;right&quot; way cos it looks cool... :P<br>
Wow, to be honest this looks incredible :D I already have an inverted LCD watch (non-casio though)
i've done this before with my old nokia phone, just&nbsp; flipping it over wasn't working, it'd needed to rotate 90 degrees., but it was very cool. i got lots of fun time spend with polarized light things.<br />
What causes it to not be visible? I guess I don't understand LCD's like I thought I did...
Well I'm probably not the right fella to talk about the technical specifications of a LCD display - but I do know that they are all built in such a way that they require polarization to be visible to the naked eye. This simple hack just exploits that and reverses the polarization to make a neat negative effect. BTW- Casio makes many watches with a factory negative display, but this useful for converting models that don't have that option. If anyone knows the answer to this please post it here :)
The light coming from the mirror behind the screen is polarized. Liquid crystal solution rotates the polarization of light when placed within a charged capacitor. The human eye is not sensitive to polarization. The polarizing film on top of the display blocks the light of certain polarity. Displays with backlight also have another polarizing film between the backlight and the display. If you want more polarized fun, play around with mirrors and polarizer films. You can also observe a fructose sugar solution or invert sugar syrup to rotate the polarization of priorly polarized light. The fact that clear sky emits slightly polarized light has been widely used in photography to make the sky appear darker compared to the scenery. To source polarizing film at no cost, you can simply strip apart a broken laptop screen.
I used to have a Motorola phone with a reverse lcd outer display... Until it got run over one day at work. Phone I have now, has colour lcd inside & out, takes pictures, plays mp3s, keeps track of stuff, does pretty much everything except work decently as a phone. I was just gonna p and m about how much better my old phone was, but then I got to thinking, "What about reversing the polarizing film on a colour lcd?"... Technowags will point out the fact that, "Colour lcds have three polarizing films". So flip one, two, or all three films, for different effects.
"Except work decently as a phone" YUP
Actually, one fun trick I did was to take the polarizer completely out of my watch and wear it around on sunny days with my polarized sunglasses. Once in a while people would notice that the watch was blank, and it'd be a fun conversation piece.
Did you try just flipping or rotating the original film over? I remember disassemabling a cheap calculator years ago and flipping the film gave a negative effect.
The factory fitted polarizing film has a sticky backing and when i took it off it got very messed up so I had to clean it with Goof Off. The problem then was I had no way of sticking it back on. It probably would have worked...
You can use a small bit of tape on the edges just to keep it in place until the cover goes on. Most of the time the cover presses enough that the film won't move. Alternatively you could do what I did with my ti-83. I had to cut sections and rotate to make them fit (rectangle, so not all parts were being filtered) so I placed a piece of packaging tape over the entire layer and continued it onto the pcb. It creates a nice internalized screen cover and dust protector. Its nice not having to worry about poking the screen when trying to point something out, and pen marks erase once I am done with them.
About This Instructable
133,421views
58favorites
License:
Bio: Brian Green is an avid lightweight backpacker and author of the popular Brian's Backpacking Blog. Originally from Southampton, England, Brian has lived in the ... More »
More by bfgreen:Plastic Soda Bottle Lid Capsule DIY - Single Use Antibiotic Ointment Blister Packs Boiling a Casio G-Shock Mudman
Add instructable to:
