After reading this article:
http://www.et.byu.edu/~bmazzeo/LTR/tech.phtml
It suddenly occurred to me that almost any toy RC car might be using this or almost similar architecture. I opened up 4 RC cars that were donated to the project and indeed they all use more or less the same configuration: All these cars have 2 H-Bridges on a small board mounted inside. Almost all the cars these days use a variation on the RX2C toy car chip (link) (i.e. pins 6,7,10,11 are the drivers for H-Bridge) and these boards can accept logic voltage levels regardless of the battery voltages. The boards that do not use the chip will usually have an equivalent daughter board that fills the same function. Furthermore- the boards are optimized to drive the motors of the cars optimally. Contrary to the article they are safe to turn on both sides of the H-Bridge at the same time by mistake - all they do is turn on braking mode.
Almost all RC cars are configures so the rear wheels are running of a power H-Bridge for the forward/reverse motion and one H-Bridge is used to run a servo or servo-like mechanism in the front wheel. There is another configuration in which the right two wheels are connected to one motor and the left two wheels connected to another and this configuration can do some interesting stunts such as turning on the spot and other tricks.
The chip specifies an additional output - "turbo mode" however I am yet to see a car with this function implemented.
If you open you car and do not find the standard configuration - do not despair - figuring out the H-Bridge inputs are easy - and usually are the pins connected to 2.2k resistor.
The steps involved in making this work:
1) remove the RC chip - more on this later.
2) solder 4 wires to the H-Bridge Terminals
3) solder a wire to the negative terminal of battery - to power the arduino
4) solder a wire to the positive side of the switch - to power the arduino..
Here is a video of this mod after we completed the mod in 25 minutes.
Once reassembled, you can control the car from the arduino - and viola! you have a robotic car!
After doing a few cars - i find that the process of conversion of a car takes about 30-40 minutes.s a
Note the cars are sensorless!
VARIANTS:
* RX2C microchip based controller/receiver
* Daughter bvoard based controller/receiver
* Analog (transistor based) H-Bridge - can be used with analogWrite and PWM to control the power
* Relay based H-Bridge for the bigger devices. This can only be turned on and off - if you want to use PWM on there - you will have to turn to a custom H-Bridge design and ditch the board.
NOTE: This mod cancels the RC functionality. I have had thought to hack the RC part to allow two arduinos (or more) to communicate via hacking the transmitter and then connecting the (disconnected) signals lines as an arduino input. thus one would kill a few birds in one stroke: a dual H-Bridge, robotic car, and half duplex RC communications between arduinos. maybe I will tacle this in the future :)
WARNING: Make sure that the switch is off while programming your fully charged vehicle -or you will have a robotic missile flying off the table at maximum speed and power. Also you can expect some weak movement of the wheels due to the H-Bridge being powered by the USB cable - even when switch is off.
Here is a video of the kids programming their own cars by themselves, and also note the cars are sensorlesss
Remove these ads by
Signing UpStep 1Modifying a car from A-Z
These pictures show the beginning of the dismantleation.
you may be able to program a PIC or something to read the turbo signal (it can be repeated a second time for checking) and activate a variety of features you installed on the controlled car.
alternatively, because human commands are so "slow" (if you have a Tx in your hands), data *may* be successfully transferred across all five pins, depending on how they are used, pwm, etc. if its pwm then maybe it can be slowed down for the data.
I simply removed the existing radio link and signal decoder, and drove the H-bridges Directly from the digital I/O pins of my arduino duemilanove. I had to remove the RF-link because it acted as an energy parasite. once this was done, I got much better function outta my "RcCarduino"
Thats what this type of project is being nick named. ( I take no credit for its inception. )
in a way, the digitally driven cars are easier to work on then the old analog type, and you thought modding your 27Mhz. version was easy. the difference is the digital cars are all surface mount instead of through hole type, so you have to be more careful when soldering.
As for helicopters - although weight is an issue - you can use the main rotor assembly with the chip from say 2-3 of them to build a tricopter. Because of the gyroscopic effect of the 2 rotors, it would be easy to control 6 PWM lines and make the thing quite stable! the other thought i had on this was that the LiPo batteries inside are usually 200-240ma batteries, whereas you can use a single 2400 laptop battery on say 3 assemblies giving you 10X the power with 3X the power requirement. also, by stripping the bodies, you can get much more weight to lift and finally you can always up the voltage if you use 2 batteries - and see if you burn out the motors or the board.... :) just a few thoughts... i am sure there will b people who can comment on this.
If you are unsure on the chip.. take a logic probe to one pin. Then activate each function on the remote control. Keep notes. You will find 4 pins are doing all the work. Solder to those chips.
Nice work!
You can even use the arduino as the logic probe (use d13) or write a simple sketch.
I then create a simple daughter board that breaks out the RX2 pins and the H bridges for the micro-controller board. I retain the removed components by placing them on the daughter board. I then connect the daughter board to the main board using the holes where the components originally were.
By doing this I retain the RF functions as triggers for the micro-controller. The signals off the RX2 can be used by the micro-controller for such things as "emergency stop" or "robot pause" which are required in some outdoor robot competitions. They can also be used to trigger different behaviors remotely while still leaving the robot autonomous. An example would be to trigger a camera to take a shot.
The micro-controller is used to send PWM signals to the H-bridges, via the daughter board. This allows you to slow down the converted cars
And yes we did use PWM on the cars as part of explaining how to operate the motors at various power levels.
Although I was gonna connect the arduino to the controller that way the arduino can control the car wirelessly, without the second arduino.
