3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to read books on a digital photo frame
How to convert (e-text) book to images and read it on a digital photo-frame
(There are also programs that can do this, more or less successful.)
My photo frame has 7" 234x480 resolution.
It does not read txt or pdf. Here is how to create images from books.
1. convert pdf to text (if necessary)
2. insert it into open office writer/ms word
3. format page
4. export to pdf
5. export pages from pdf to images
6. resize and convert images
 Latest version is on http://dbojan.co.cc
Step 11. convert pdf to text, and Reflow text (if necessary)
If your text is in pdf format, here is how to convert pdf to text:
 -export pdt2txt using "somepdf 2 text" converter.
Picture 1:
 1. Open program in "Somepdf 2 text converter.
 2. Click on Play to convert pdf to text.
Reflow text
if your text lines break in the middle of the page use using reflow program.
Picture 2:
 1. Open text in Notepad2, or plain notepad.
 2. Select the shortest line you need to reflow.
 3. You can see at the bottom its length. "Sel" is 9. Or count manually.
Picture 3:
 1. drag and drop file on reflow.
 2. Enter shortest line -1. Here it is: 9 - 1 = 8
 3. Press Go.
If lines in your text are broken, but every paragraph starts with new line, check "Use empty lines as a separator".
Picture 4:
 You can see fixed line.
1 comment
Apr 9, 2011. 12:34 AMmadpotato says:
The format fits the original when i open this in a Notepad but when i put it into Writer the lines start breaking. What do i do?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dbojan
