How to Cool Your Home Naturally Without Air Conditioning
Introduction: How to Cool Your Home Naturally Without Air Conditioning
Air Conditioners are some of the biggest power consuming appliances most houses have. They have motors that use 1500 watts or more and are run for 8 hours or more in summer.
Just turning off the air conditioner can save you BIG money on your power bill but how do you stay cool without it ?
There are several natural passive ways to cool a house and most are very inexpensive or free.
Passive means no motor or power source required and that's a good thing!
The first way is to plant trees:
Trees planted on south side of house will naturally shade the house and decrease sunlight entering through windows. Plant deciduous trees (ones that lose their leaves) if you want the sun to shine on the house in winter or Evergreen trees (needle leaf) if you want year round shade.
Trees take time to grow and must be fed and watered but some trees like the willows and poplars can grow 6 feet in a year and provide lots of shade.
Trees also increase the value of your house and just make the yard much nicer.
You can buy seedling trees very cheap but for faster growing get a bigger more mature tree.
Step 1: Build a Porch
Porches that cover the south side of a house and doors and windows will decrease the suns heat and light penetration into the house.
Windows on the south side will get a lot of sunlight and that can increase heat in the house but if you do not want to cover the windows to block the view a porch will shade the windows and still allow you to see outside.
The air under a porch is shaded and cooler so it makes a great place to hang out on hot summer days. It will also cool the air entering the house if you open the door and windows under the porch.
just a slight breeze blowing under a shaded porch and through the doors and windows will cool off a home considerably!
This is the front porch on my cabin:
Step 2: Passive Roof Turbines
A passive roof turbine exhausts warm air from your attic and house.
When even a slight breeze turns it will pull warm air out and bring cool air in through open doors and windows.
These are great at reducing heat in a house and helps to remove humidity, stale air, carbon monoxide and air pollution that is trapped in the house.
These come in different sizes and for larger homes you may want two or three.
I have one on my cabin and it really works to cool the whole house down!
Step 3: Use Fans
Fans are not passive and require power but they use much much less power than an air conditioner and can really reduce your power bill.
For best results a window box fan placed in a north window that is shaded can really bring in the cool air.
I like to have one placed so it blows over my bed at night and just the air moving will keep you cooler without cooling the entire house.
Ceiling fans are two way and can be used to pull cool air up or blow warm air down. Box fans move a lot of air and small personal fans will cool just a person and not the house.
When fans are used with shade trees, a front porch, and a roof turbine the house can be kept at a very comfortable level even on hot sunny days without expensive air conditioning.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Whole house (attic) fans are great to cool a house down quite a bit but you need to think about several things---these move a LOT of air so you want it to be from the right (coolest) places and to exhaust it to some place where the hot air can escape and not enter back into the house (if you have a multi layer roof or near a chimney etc) They can be LOUD and shake the house. You need to mount them to rigid framework in the attic and have a good size space for the intake---this is covered by a louvered register--but in the WINTER this will let IN the cold so plan to remove and cover or use a magnetized cover and insulation. For some a whole house fan can pull nice cool air from the basement ; for some it will need to come from a shaded side of the house or just be to move air in a current to cool and ventilate. If you need to close all the windows you can air lock.
    We found that an in-the-room standing AC unit does not take that much power (we are on-grid tho!) as trying to use the smaller window units; and certainly a LOT less in initial expense and maintanence as a whole house HVAC unit would; they cost around $300 and come with panels for your windows or you can custom make a panel to vent the tubing; the condensed water goes into a contained bucket (if there is any; we have very little) and you do need to check that if you cannot drain it via a hose. The good things about these is you are not trying to cool your entire house (unless your house is not that big!) and so you only need to have it on when you need it. In a house with 4 people with asthma---this is a need.
    Other ways to save your cool::: heavy curtains; shade shrubs rather than full trees--these can be a great fast shade giver (along with vines!) while your trees grow) old fashioned fan blowing over a block of ice; shade screens from tarps or drop cloths; awnings; pergolas; transom windows.
    Also a solar powered house/attic fan would be great! One with a battery - even better to continue cooling the house at night.
    In Texas it gets HOT in summer. I"m not sure this would be sufficient. Sumtimes it only get down into the ninties at night during summer.
