3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to crack a masterlock padlock.
This little instructable will demonstrate how to narrow down the possible combinations for your lock from over 60,000 to 80. This is good for if you lose "your" combination.
Step 1Knowing thy lock.
Knowing thy lock.
Before you find your numbers, you must know a few things about your lock.
First of all, there is a dial, a body, and a clasp (The U shaped thing on the top that comes out when unlocked).
When you open your lock you would normally spin the dial right a few times to reset, then go to your first number. Then, you would turn left, passing your first number once, then stopping on your second number. Finally, you would turn right again to your third, and final number and pull on clasp.
Okay, now you know thy lock.
58 comments
1-40 of 58next »
Nov 25, 2011. 7:51 PMjrunyan1 says:
Easier way, just cut an "M" out of a pop can, fold in the two sides so it lookes sorta like a t, wrap it around the Pole , push down, squeeze, and pull
Sep 17, 2011. 8:29 AMevindrews says:
So I can't use 12 and 8? Because the last number of my combination IS 12. also, if you get stuck on 3.5, do I move the lock wheel to 4, or 5?
And how Exact DO I need to be doing the numbers?
Nov 22, 2011. 7:33 PMadavis34 says:
no its you need to FIND 12 #'s not 8 #'s
Nov 18, 2011. 5:46 PMriff raff says:
Ha! It worked! Had an old Master lock in the junk drawer; no one could remember the combination. Got it on the 18th try. Thanks!
Oct 10, 2011. 10:56 PMrshaw94 says:
i went through all your steps using a lock with the key slot on the back, and did all the combinations but no luck /: thanks though.
Jul 19, 2010. 10:17 AMnoremakk says:
"Now remove any 2nd numbers +/- 2 from your third." What does this mean? Do I remove the numbers from the second list that are within two numbers of the third?
Aug 17, 2011. 12:37 PMQuestionConvenience says:
Yes, I think that you remove any numbers from the list of 2nd numbers that are within 2 of your 3rd number. For example, if your 3rd number is "38", you would remove 36, 37, 38, 39, and 40 from your list of 2nd numbers (if they are on that list). I'm still trying out this technique, but that's what I think Step 5 meant.
Peace
Aug 17, 2011. 1:32 PMQuestionConvenience says:
Yep! Just worked for me. Doublecheck your numbers, and be patient! Keep track of the numbers you tried. Nice instructable!
Oct 28, 2010. 6:01 PMplatinum15 says:
i think if its a negative number, you add -2, and if its a positive number, add +2. see if it works and sorry if im wrong :P
May 5, 2010. 11:22 AMjdollar says:
I think I found a way to narrow the possible "try" combinations down to only TEN.
I think that I found a way to discover what the FIRST number in the three-number combination is. So if you have the first and the last number you only have to try ten combination AT MOST, to find out what the correct one is.
http://4urnfo.com/lockpicking/first-number-of-combination.htm
jdollar
Nov 29, 2007. 7:47 AMbombtech91 says:
anoher way to narrow combos is to remember... First number is always LARGEST.. se4cond number is usually smallest.. and you have she last... don't feel like doin the math, but that removes quite a few possibilites
May 5, 2010. 11:15 AMjdollar says:
The first number is NOT always the largest.
I have one that is 18-24-34  master lock is purple in color.
jdollar
Nov 11, 2008. 10:36 PMDaPaulness332 says:
yea, mine's 9-12-19 for school
Sep 11, 2008. 9:37 AMchaosrob says:
Maybe for all the locks that you've seen. I have one that is 0-20-26. Hmmm, unless you think the "0" is considered the highest number (on combo locks)
Jun 23, 2009. 9:41 AMMoeMonkey says:
my lock goes up to 39 like I think most Master Locks so I guess 0 is like the Ace in Cards, it has too numbers, 0 can be 40
Apr 29, 2008. 2:17 PMSypran says:
not true my old locker combo before i switched lockers was 17 47 43...
Jan 25, 2008. 2:18 PMbowmaster says:
My school lock combo is 1-27-1 I just broke your theory and last year my combo was 13-19-13
Dec 8, 2007. 10:46 PMhowboutitbru says:
no always man my pe one starts with like something aroudn 9 nad my third number is 35... 35>1st number
Mar 24, 2010. 12:01 PMhowdoesthiswork says:
 There's an app for that! Crack a combination lock by ear with the iPhone app called "Padlock!" Pretty fun!
Mar 20, 2010. 4:02 AMleft4dead4432 says:
i have done that before i just opened the backside of it and opened all the way through and it just fell apart.
Jan 14, 2010. 2:51 PMPeekadosies says:
You put Step 5 in step 4
=P
Dec 28, 2009. 11:05 PMpete54321 says:
 with step three, you chose 19 out of 12 possible numbers, how do we know which number to choose?
also i read on another site that you should cross out all the numbers which arent whole numbers, should we do the same?
thanks
Oct 24, 2009. 6:53 PMRobotWoods says:
 There's also the new iPhone App 'LockGenie' which helps crack the combinations and does all of the combination prep for you. http://itunes.com/apps/lockgenie
Oct 12, 2009. 2:51 PMtomtortoise says:
sorry switch 1st and 3rd
Oct 12, 2009. 2:50 PMtomtortoise says:
i got to this step and my numbers are 1st 21
        2nd 3,7,11,15,19,23,27,31,35,39
        3rd 1,5,9,13,17,21,25,29,33,37
and if i remove any numbers +/- 2 from the third i lose all of the numbers
Sep 28, 2009. 4:00 PMr3nrut says:
can zero be a number?
Oct 4, 2009. 1:14 PMwiilikepi says:
yes =D
Sep 12, 2009. 5:28 AMmemyselfand1 says:
We have these on almost every one of our school lockers. Some things we do are: 1. kick them. They won't open if you do it enough 2. watch people entering their codes, then put their lock on backwards 3. switch peoples locks around so there is a whole myriad of possibilities with these locks.
Aug 12, 2009. 2:38 AMaj301292 says:
this could work. i just tryed it on my locker code for school, which is one of the ones with a key lock in the back, for teacher inspections. this theory workes because with these locks close enough is good enough
Jun 27, 2009. 11:02 PMIdeal_Ideas91 says:
This Dont Work! I have tried this on master locks and they lock on every digit! I dont know if they changed the design but I do know the thing wont lock up on on 2 different numbers
Sep 14, 2008. 6:58 PMBEAST14 says:
That would take a long time and a lot of thinking,...is there an easier way?
Mar 4, 2009. 7:11 PMmusicninja17 says:
Once you get the hang of it, you should be able to do this in under 20 mins...ther whole point of this trick is that you can still use your lock again...
Oct 4, 2008. 10:04 PMCapinPorcupine says:
Yea. take a thin falt head and jam it into the edges of the dial until there all up the pry the dial off and rip up the insides of the lock
Jun 6, 2007. 5:31 PMassasin says:
Master lock only?
Mar 4, 2009. 7:10 PMmusicninja17 says:
Not necessarily... others do work...
Jul 7, 2008. 5:28 PMDandy in the Ghetto says:
When I was in PE in highschool, we used to smash the padlock on on the top of the side that the clasp opens up on. I would do this with another lock. It opens right up after a few solid whacks. You can close it again after too, at least for the first 15 or 20 times you do it. You really have to beat the hell out of it though
Mar 4, 2009. 7:09 PMmusicninja17 says:
Its because the little springy piece would be compressed there, so it would let the clasp through...
Aug 20, 2007. 3:27 PMmoomoocows says:
i have a padlock with the brand club i was wondering if theres any other way to do this because when i tried turn and yank i only got one number.
Mar 4, 2009. 7:08 PMmusicninja17 says:
That should be your third number.....old style masterlocks work this way too...
Jan 15, 2009. 4:52 PMMusicman41 says:
I tried a club lock, and the third number i got was correct. Everything else worked too.
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:nickbadal
