How to create Romantic touch in Wedding by creativegirlz
Step 2: Making the Candles Moulds (For 1 table only)
Floating Candles are easily available in market but to make something different, one need to follow a different plan.
For making floating moulds, take an empty aluminium can and wash it and dry.
First cut it top. For that, make a hole first, then insert your scissors in it and cut off the top. Be careful with tin edges.
Cut from bottom too but keep the one inch bottom area so it will make another floating candle later on.
Now take the middle piece and cut it in half.
Take a small bottle that is smaller than the tin piece and its bottom just right for a floating candle. Put a tin piece beneath it in the center.
Fold the tin piece upwards, making folds in it.
It will take your strength but the result is worth it.
Fold all sides up, making altogether about 4.
It must have 1 inch walls to put gel in it.
Repeat the same process with second piece of tin.
Now you have 3 floating moulds (2 folded, 1 bottom of can).
Take another can and repeat step one and you will have 6 moulds in the end.
Take another can and cut only top piece, it will make the center candle.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
