3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to create a fiber optic starfield ceiling
Step 2Cut your illuminator port-holes
The next step is to drill and temporarily mount your illuminator.
I placed the light-box at the top of the nursery closet. It runs off of a 12v supply, which I'll *eventually* run through the attic.
Find out exactly where you want to place it and turn it on. You'll see the two powerful LEDs create a spotlight on the ceiling. This is where you will need to drill. My bundled fiber required 1/2" holes into the ceiling. After drilling, run the fiber into the ceiling. This helps if you have two people... at least, I can imagine it would. My pregnant wife was... erm... unavailable to assist.
After all of the fiber is safely coiled inside the attic, we can begin with the meat of the project - drilling, filling and gluing.
4 comments
Oct 8, 2009. 9:32 AMsupermitten says:
On the first photo... which way is up? I'm not sure what I'm looking at and I would like to try this project for myself. Though I'm having some trouble orienting myself :)
*thanks for this instructable btw!
Oct 8, 2009. 11:12 AMsupermitten says:
In the first photo for Step 2.  It's hard to distinguish the left side wall from the ceiling as they are the same texture.  But I looked at it again after reading your explaination and I'm beginning to see it.  Thanks! :)
Oct 8, 2009. 10:49 AMthebritelite says:
Sensory stimulation for kids is big business.
Did you use glue form your vendor, Wiedamark?  These acrylic fiberoptics are damaged by all solvent based glues (and white-out).  You can only use water-based glue or epoxy.  Once damaged by solvent, all light will leak out of the "light pipe" at  that point.
Your vendor, Wiedamark, is a good one: http://www.wiedamark.com/fiberopticstarfieldceilings.aspx I also recommend these guys: http://www.fiberopticproducts.com/Ceiling.htm
They both sell complete kits for star ceilings.
Oct 6, 2009. 5:46 AMPhalstar98 says:
Very nice and looks simple to do! Congratulations on your first child as well! Where did you get the fiber cable from, and how much did it and the illuminator cost? Thanks! Great Job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:mikegalloway
I tend to start really big projects and then walk away for a few years. My MAME box took 10 years to build, all while I hauled an empty Centipedes arcade cabinet between 3 apartments and two houses. ...
more »
