3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create a REALISTIC BURN using makeup
Step 4Cut the silk strips
Cut the silk strips
Cut silk strips from the nail silk or mouseline. I used three strips for this makeup, each approx 1 cm x 3cm (½ inch x 1½ inch). It doesn’t matter if the edges are neat, as everything will be glued flat.
What is important is that you follow the fabric direction, and avoid cutting across the silk at an angle. When you hold each end of the tab and pull, you should find the silk does not stretch. (see illustration)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:stuartbray(Learn Prosthetic Makeup)
I create and teach makeup effects and prosthetics for a living. I love The B52's, good sarcasm and boring things like history, science and Radio 4.
