3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create a REALISTIC BURN using makeup
Step 6Glue the silk tabs in place
Apply glue behind the ear lobe, allowing it to dry thoroughly. Then add a little to the silk tab, allowing that to dry too. Press the dried, glued parts together firmly and stretch the ear across as far as is comfortable, ensuring there is plenty of silk available for both the ear and the cheek.
Apply glue through the silk and onto the cheek. Peel the silk away from the cheek, and allow it to dry fully, before stretching the ear again and pressing the silk firmly into place. The ear should hold in place.
Silk is good for this process because it does not stretch, making the skin do all the stretching. This gives you a distortion onto which we can build. If glued correctly, the silk appears quite translucent, making it easy to hide.
Then do the same to the lip and the eye. Be careful when using adhesive around the eyes and lips. It’s always worth doing a small patch test to check sensitivity with adhesives, especially as you will be stressing the skin surface by pulling on it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:stuartbray(Learn Prosthetic Makeup)
I create and teach makeup effects and prosthetics for a living. I love The B52's, good sarcasm and boring things like history, science and Radio 4.
