3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Create a REALISTIC BURN using makeup
Step 7Apply the gelatine
Apply the gelatine
Be extremely careful when using molten gelatine! It is possible to cause serious (real) burns to skin if you apply hot, molten gelatine.
Melt the gelatine and add a little water to the mixture to help lower the melting temperature. Heat up the gelatine again now mixed with the water, and allow it to cool sufficiently before applying to your model.
Try a small sample on the back of your own hand to test the gelatine for heat and usability. If it cools too much, it may need a little reheating.
Start to build up gelatine on the area where you want your burn to be, going over your flattened hair and covering your silk tabs. Create smooth and rough areas, stretching and stringing the gelatine as it cools to create a variety of textures.
Blend some areas into the skin by dragging the gelatine firmly onto the face. In other areas, create ridges and hard edges where the texture suddenly stops. This variety of textures on the surface will help create a natural, random look.
Keep building slowly, taking your time to ensure that the gelatine is always at a safe temperature
4 comments
Oct 22, 2010. 2:46 PMBlueSuns says:
Is it just regular gelatin, like Jello but without the flavoring? Or is it special gelatin that you have to get at a specialty store?
Oct 24, 2010. 11:33 AMBlueSuns says:
K thank you!
Oct 24, 2010. 9:01 PMBlueSuns says:
I also forgot to ask, but does it dry and stick on its own or would i need to purchase spirit gum?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:stuartbray(Learn Prosthetic Makeup)
I create and teach makeup effects and prosthetics for a living. I love The B52's, good sarcasm and boring things like history, science and Radio 4.
