Step 8Practice is good!...Let's get Detailed!!
Practice will make the road to perfection much easier to travel along, and the more you traverse this path, the more you will become your own guide. Making a perfect bass guitar from scratch the very first time is not easy and unless you are some sort of musical savant you have probably made a few mistakes so far. So take this chance to rethink your design before you make your second prototype bass guitar.
Some things to think about:
1. What wood will you use for the new neck?( I chose African Padauk hardwood; this wood will produce a deeper overtone. Also this kind of wood has an amazing natural red orange color)
2.What wood will you choose for the new fretboard? ( I also chose African Padauk for the new fretboard. Padauk tends to have variations in its colors and the piece i chose for the fretboard has a slightly darker hue then the piece i am using for the neck.)
3. What wood will you use for the new body? ( I decided to use a portion of the body from Prototype#1, My plan was to incorporate this with more Padauk in a complex laminate body)
4. Will you change the style of truss rod in the neck? ( I changed my truss rod to a double action truss rod to compensate for the extra weight of the new wood)
5. Now that you have learned a little bit about the details of constructing a bass guitar, what else can you add or change to create an ultimate Bass Axe? ( Considering that I am more comfortable playing while sitting down, I designed the body for my Prototype #2 to fit comfortably to my lap.)
HOPEFULLY YOU ARE DECIDING TO NOT GIVE UP. IF YOU ARE GIVING UP, WHY DID YOU EVEN START?
Add Comment
