3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to create one completely focused image from several partially focused
I suggest to use Helicon Focus software. Windows and Mac versions are available at d-Stidio's site
The program is designed for macrophotography, microphotography and hyperfocal landscape photography to cope with the shallow depth-of-field problem.
Helicon Focus also aligns images as objects often change their size and position from shot to shot. This function is especially important for macrophotography.
Step 1Creating stack of images
You are supposed to work with an optical microscope and a digital camera, or with additional macrolens on digital camera.
- Set your digital camera to manual focusing mode(!!) and set the focus to infinity.
- Manual mode (shutter speed and exposure) is also preferable to avoid fluctuation of brightness.
- Adjust the microscope to make the topmost area of the object sharp.
- Take a shot. Use the remote control (if available) to minimize any shaking of the camera.
- Using the fine adjustment controls, the shift sharp area a little down.
- Take a shot.
- Use small, roughly regular steps while adjusting the mircoscope and taking shots. It is better when sharp areas overlap.
- Take shots until you reach the lowest area of the scene.
- Copy images from the camera to your computer.
7 comments
Jun 10, 2009. 10:19 PMDr.Gadget says:
Helicon Focus is wonderful and reasonably priced, but not free. You might also consider Allen Hadley's CombineZP. It performs similar functions and is free. The math behind the two programs is different, so some enthusiasts use both - alternating according to subject matter.:
http://www.microscopy-uk.org.uk/mag/indexmag.html?http://www.microscopy-uk.org.uk/mag/artdec02/ahcombinez.html
Jan 28, 2009. 7:08 PMCameronSS says:
Is this essentially the same thing that CS4 does? I might try this sometime, I like macro photography, but the shallow DOF is always a problem.
Jan 28, 2009. 10:45 PMBobS says:
CombineZm is freeware! Download. Does the same thing.
Jan 28, 2009. 5:24 PMWeissensteinburg says:
That's really neat, thanks for posting it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:vvprok
