3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to create simple animatronics- part one: using the MAKE controller
Step 7Additional info
This barely scratches the surface of the capabilities of the MAKE controller. There is a ton of info on the MakingThings website: http://www.makingthings.com
The digital ouputs of the controller's application board can be used to hook up everything from lights and motors to actuators and solenoids so if you want to build a 1000lb. animatronic dinosaur that moves and roars as people walk by your house it's definitely possible. You could even use solenoid/electronic air valves and use air muscles.
As for the analog inputs, they can accept switches, motion sensors, gyroscopes, potentiometers, etc. Just about anything that can generate a sigal up to 3.3v can be used since the board has a built in analog to digital converter. One of the things I've been looking at is using a two axis accelerometer.
It could be hot glued to a cap on the top of your head and as your head tilted forward and back or side to side it would put out a corresponding voltage from 0 to 3.3v and its input voltage is 3.3v which is perfect for connecting to the MAKE controller. Accelerometers like this are often used in video game controllers as tilt sensors.
There is a really great page on all kinds of sensors here:
http://itp.nyu.edu/physcomp/sensors/Reports/Reports
Both the inputs and outputs are powered but they can only provide so much power. Each of the outputs is limited to 1amp. Fortunately you can just move a jumper on the application board to provide a seperate power source for both inputs and outputs. All in all, the MAKE controller is a dream come true for anyone that wants to build animatronics/motion control systems.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
620
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
