How to crochet a Nintendo DS case (for the Lion Brand Yarn Challenge)
 by Fruppi
This is the case I came up with for my Nintendo DS. It's got 6 game pockets and a strap to hold the DS in place. I used Caron Simply Soft in plum wine and chocolate (Sorry, Lion! I didn't know I was going to submit this to a Lion-sponsored contest or I would've used Vanna White yarn), plus some scrap white yarn and black embroidery floss. I used a size F hook.
I made the back with the pockets first. I just crocheted in the front of the stitches and left the back loop to start the pockets in. Then I sewed up the sides.
Then I made the front (which is slightly larger to wrap around the sides) and sewed it to the back and up the sides. Then the real inspiration struck and I decided to add the mushrooms. I did them in two pieces and used the very long tail I left from the stems to make the spots.
The strap was about 12 ch or so long with a buttonhole.
And that's it! For a more detailed pattern, leave a comment or message me or whatever you do on instructables (I'm new here). Hope you like it!
Edit: Here is the actual pattern. Sorry I held off for so long!
Back
1. With MC ch 31. Turn.
2. Sc in each ch across. Ch 1. Turn. (30 st)
3. Sc in next 2 sc *(Sc in the front loop only of the next 8 sc). Sc in next sc. Repeat from * twice. Sc in next 2 sc. Ch 1. Turn. (30 st)
4-9. Sc in each sc across. Ch 1. Turn. (30 st)
10. Repeat 3, but stitch in the back loop of the stitches this time.
11.-15 Repeat 4-9. End off, leaving very long sewing length.
Front
1. With MC, ch 35. Turn.
2-18. Sc in each sc across. Ch 1. Turn. (34 st)
On last row, end off and weave in end.
Pockets
1. With CC, join in remaining loops you didn't use in steps 3 and 10. Join in first loop. Ch 1, sc in same loop. Sc 1 in each loop across. Ch 1. Turn. (8 st)
2.-6. Sc in each sc across. Ch 1. Turn (8 st)
7. Repeat for each set of loops on back. 6 total.
Then we get to sew everything on/together! With a yarn needle and with the piece turned inside out, sew sides and bottom of front and back together. Sew sides of pockets down.
Strap
1. Ch 12. Turn.
2. Sc in each sc across until the last sc. Work 6 sc into last sc. (Adjust according to button size). Turn. (18 st)
3. Sc in each sc across. End off with sewing length (18 st)
Sew to inside of back with yarn needle. Sew button on front according to strap length (mine was about 1 1/2")
Mushroom
I worked this in two pieces. I did the top from top to bottom. I sewed the bottom on the front first and left a very long tail on the back. I then used the tail to make the spots.
Back
Front
Pockets
Strap
1. Ch 12. Turn.
Mushroom
Norazom says: Aug 17, 2012. 3:58 AM
Hi, I'm pretty new to crocheting and reading pattern. How do I make the pockets for the case?
Rayna says: Jan 24, 2008. 2:56 PM
Just 'me-tooing' on wanting a copy of the pattern. If you do share, will you be posting something on here or just emailing one around? Let us know, it's lovely!
Fruppi (author) in reply to RaynaJan 25, 2008. 6:56 AM
I've been e-mailing on request, so one is heading your way!
WildMist in reply to FruppiOct 15, 2011. 11:28 AM
Could you send me the pattern too, please. My grandson just let me know he wants one of these
Fruppi (author) in reply to WildMistOct 15, 2011. 3:42 PM
It's posted above. I got tired of e-mailing it!
StayseaKay in reply to FruppiJul 1, 2009. 7:17 AM
can i get one too please :) i just love this pattern. its so cute. i cant wait to try it. thankyou for sharing it with us.
ctrulson says: Apr 5, 2011. 10:25 AM
Great pattern. I want to add a strap so that my child can carry it on his shoulder, what would you suggest? Great to add the mushrooms, but my son says he wants something else on his, so I will be figuring that out!!
Fruppi (author) in reply to ctrulsonApr 7, 2011. 2:50 PM
I guess I would just crochet a long chain of doubles or triples and attach it to both ends. You could always sew on a fabric strip or something similar if you don't want to crochet anything extra. I've seen some other embellishments on the same pattern done by people on ravelry.com. Also if you like the Mario theme but don't like the mushrooms, you can find 8-bit pictures of Mario or other characters and that makes them easy to chart for crochet. Try spritestich.com for other geeky ideas (if that's the route you want!).
spacegirl94 says: Apr 30, 2009. 7:13 AM
could you possible send me more detailed instructions to?
Fruppi (author) in reply to spacegirl94Apr 30, 2009. 2:20 PM
The pattern is right up there...if you have specific questions, I'll do my best with them :).
swtullie says: Apr 19, 2009. 9:33 AM
ok for example, on working the front 4.-9., has 6 rows and then on 11.-15. which has 5 rows says to repeat 4-9 which again is 6....so am i supposed to do 5 or 6 and also when working on the front it ends up with 15 or 16 rows but the back has 18 and is wider it doesnt really fit together...sry lol
Fruppi (author) in reply to swtullieApr 19, 2009. 2:14 PM
Okay, it looks like I had a little math mistake there and I believe I intended for it to be 6 rows each time. The back is supposed to be bigger than the front because it will wrap around to form sides and the bottom. The difference in size should be about the width of the DS. and it should fit pretty nicely once its sewn together.
swtullie in reply to FruppiApr 20, 2009. 2:09 PM
yeah but if the sides AND top and bottom of each part are different lengths it cant be sewn together really...sry i tryed its just not working..maybe im doing something wrong O.O
Fruppi (author) in reply to swtullieApr 30, 2009. 2:19 PM
Okay, sew the bottoms and sides together, and the top should be the right height once you put the DS in. You'll probably have to fudge the bottom corners a bit, but it can be done! :)
jajinomoto says: Apr 29, 2009. 10:46 AM
Nice, here is more case for nintendo ds, http://www.colordrives.com/nintendo-ds-cases.html
swtullie says: Apr 18, 2009. 6:24 PM
this is great =] i started on this pattern but it seems really big, bigger than the ds lol can u send me the more detailed instructions? i think i could better understand it with them lol
Fruppi (author) in reply to swtullieApr 18, 2009. 9:02 PM
I don't know how much I can really clarify the instructions without specific questions. It sounds like you might want to try to use either a smaller hook or a lighter yarn. That might help you get the right gauge.
smacey says: Mar 17, 2009. 6:44 PM
what does loop mean in the pocket part
Fruppi (author) in reply to smaceyMar 19, 2009. 11:39 AM
You don't have to do any chain stitches. You will just start your single crochets in the front loop of the crochet stitch that you left when you made the front. Check out this video http://www.nexstitch.com/v_front_back_loop_stitch.html
If it's too late and you didn't leave the front loops free on the main piece, I would recommend chaining 9 stitches and making a square that is the size recommended. You can then just stitch the bottom and the sides of the squares on to form pockets. It won't be quite as efficient, but it should work. :)
smacey says: Mar 17, 2009. 6:42 PM
how many chain stiches do i have to do on the pockets
rainbowxx says: Feb 24, 2009. 3:29 PM
This is adorable! I'd love to be able to make something like this. I have a case for my DS, but it's a little too bulky to be very portable.
smacey says: Feb 2, 2009. 5:12 PM
Please email me a more clearer description to me please im only 14 so please send me more detail im confused with the words back and front. Sorry im pretty much a beginner.
Fruppi (author) in reply to smaceyFeb 3, 2009. 6:19 PM
(removed by author or community request)
Fruppi (author) in reply to FruppiFeb 3, 2009. 6:33 PM
Try one of the videos on this page. I think they do a good job of showing that stitch. *Click here*
Fruppi (author) in reply to FruppiFeb 3, 2009. 6:34 PM
Oh...how do you delete your own comment without having it say "removed by community request? Anyone know?
legokevin360 says: Jul 15, 2008. 1:54 PM
its create not crochet
Fruppi (author) in reply to legokevin360Jul 18, 2008. 3:25 PM
Ummm...I create with crochet!
ChibiAngel says: Jun 30, 2008. 9:45 PM
um..I just started crochetting, and i'd LOVE do this! so, um..can u please send me a more detailed description? um..i'm sorry i'm only 14..i really need a lot of help..T-T please help?
thesatxrose says: Jun 12, 2008. 9:20 AM
I'd LOVE to have the pattern for this!! I have a lot of scrap yarn laying around and this would be an ideal way to use some of it up. This is awesome and so much nicer for females to carry around!!
veggienoodles says: Jun 11, 2008. 8:36 AM
I'd love to receive the pattern for this DS cozy. I'm new to crochet and I love my DS and I'd love to make this little case for it.
cartoonprincess says: May 25, 2008. 1:41 PM
I'd love one too! Your creation is great because it's different and when other kids are talking i can say "i bet you don't have one of these!" Nice Job! xx
cartoonprincess in reply to cartoonprincessMay 25, 2008. 1:40 PM
I'd love one too (a more detailed pattern) ! Your creation is great because it's different and when other kids are talking i can say "i bet you don't have one of these!" Nice Job! xx
phiena says: May 22, 2008. 12:49 AM
Loveeee this! I am also new here... I would love to have the pattern! I had just recently purchased a nintendo ds and I'm dying for the perfect cover and this is it! Where could I get the instruction ?? by email or would it be posted here? thanks!
lrccook says: May 7, 2008. 1:39 PM
being a freak for crochet and my ds...i would love to have the pattern. i am new to the site as well so i don't know if you just post the pattern or reply to the comment??? anyways, really good job!
zombiehottie0900 says: May 7, 2008. 10:33 AM
i would also really love either some more detailed instructions or a pattern...please?
sarasmom says: May 6, 2008. 10:40 AM
Fruppi, Can I get the pattern as well? My daughter just bought her a DS this past weekend with money she has saved from good grades and birthday gifts. I'd love to make this for her. Sara's mom
prolixphantasm says: May 2, 2008. 11:04 AM
Wow, that's really lovely! I just bought a DS the other day and I'd love to make a cozy for it. Could you please send me the whole pattern? That would be great!
jesuisravi says: Apr 30, 2008. 2:04 PM
Hi, I'm new here too. Any chance we could have a chart for this? It makes me so happy.
Fruppi (author) in reply to jesuisraviMay 1, 2008. 1:59 PM
Well, I don't really have a chart, but if you check your inbox, there's a pattern in there for you. The only thing I charted was the mushroom, and you can see that in the slideshow.
jesuisravi in reply to FruppiMay 2, 2008. 1:07 AM
Oh man, thanks so much. I'll get right on it asap. x
sukigirl says: Feb 29, 2008. 9:52 AM
What a great idea! I love how you can charge it in it's case and that it has a spot for your games. But the best is the mushrooms! Thanks for the offer of the pattern!
jessyratfink says: Feb 27, 2008. 5:36 PM
I somehow missed this! I absolutely love it. I'm going to be making PSP & DS cases out of felt soon. :D
Fruppi (author) in reply to jessyratfinkFeb 28, 2008. 2:30 PM
Sounds very cool and I'd like to see them :)
asyrith says: Feb 21, 2008. 9:42 PM
Wow. I am freaking in love with this. So, I can't crochet to save my life...do any of you more talented folk want to be paid a not too outrageous fee for such a wonderful item?
Fruppi (author) in reply to asyrithFeb 24, 2008. 9:10 AM
Oh hmmm.... I don't really know, actually. I've been kind of wavering about whether or not I want to crochet for cash...I've done a few commissioned projects, but I ruin my wrists enough alone on my own projects, let alone everyone else's :). Then again, it's definitely a more enjoyable way of making money than my actual job... So I guess the short answer is, I'll think about it?
babbs36 says: Feb 9, 2008. 3:54 AM
I would love to have the pattern!Both my kids got them for thier birthdays.Excellent idea!
kaneko says: Feb 3, 2008. 9:41 PM
hahah i want pattern plz! nice for protecting ds, while keeping it all nice and soft i guess haha anyways, nice job :P
sdroid says: Jan 29, 2008. 4:59 PM
I really love this pattern! I've been trying to find something for my DS for a while, and I think this will work :D It would be greatly appreciated if I could get the pattern. Thanks very much.
Queenmuma1 says: Jan 25, 2008. 12:02 PM
I would love this pattern, I am still a beginner, details work best with me. Thanks for sharing.
anngel369 says: Jan 24, 2008. 10:44 PM
really cute case! i would love the pattern to this!
babequilter says: Jan 23, 2008. 4:21 PM
This is awesome Fruppi! I love things that are both really cute and really useful! Keep the creative juices flowing!
Fruppi (author) in reply to babequilterJan 24, 2008. 7:06 AM
Thanks, babequilter :D
Zontee at Lion Brand says: Jan 21, 2008. 8:40 AM
So cute, Fruppi! I love that it's Super Mario inspired. (I've crocheted some Super Mario things for my brother and he just loves them.)
stinkymum says: Jan 21, 2008. 4:07 AM
This is a very unusual project and probably you could adapt it to make other things as well!
calm43 says: Jan 20, 2008. 12:16 PM
Looks incredible, dying to try one for my grandchildren but would like to have more detailed crochet instructions if possible.
RollyB says: Jan 18, 2008. 9:32 AM
I love this....and I would love a copy of the instructions please.
EstherC724 says: Jan 18, 2008. 5:44 AM
I love this idea and for christmas all three of my grandchildren got the nintendo DS system so I am sure they would love their own personalized cover so yes please send on the instructions.
mitchmarch2006 says: Jan 17, 2008. 5:17 PM
You did a great job. As the others I would like the pattern instructions, if you have them. My granddaughter would love one of these! You go girl!!
AwlB says: Jan 12, 2008. 12:44 AM
Id love a more detailed pattern please
deadalchemist says: Jan 11, 2008. 9:24 PM
If you could write out a detailed pattern and share it; that would be great! I'd love to make it as a gift if you're willing to share. For more nintendo charts (its for cross stitch but as you know we can crochet them) check out www.spritestitch.com I found the website through Instructables!
stranoster says: Jan 11, 2008. 3:51 PM
I'd love an instructable about how to crochet things as well. I hope you make one because you seem really good. Brilliant work.
GorillazMiko says: Jan 11, 2008. 3:42 PM
Great job! The mushrooms were a great addition, the socket things that holds the games are great too! Nice job! +1 rating.
lotwilight says: Jan 11, 2008. 12:44 PM
Hey Fruppi, That is too cute! I would love more pattern info.
canida says: Jan 11, 2008. 8:18 AM
Cute- I love the mushrooms! If you get really inspired, you could put other characters on the pockets in the back. A koopa turtle would be pretty fabulous as well. ;)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
