Lots of people use plarn to make sturdy tote bags and market bags. This is a great idea – turning a lot of plastic bags which would have ended up in landfill and converting them into something which has the same purpose, but is stronger and can be used again and again, which cuts down on needing new plastic bags – recycling, re-using and reducing ![]()
I’ve started gardening on my balcony recently, and came across the ‘air-pot’ system. Air pots are a kind of planter with an egg-box-like surface and lots of holes. Normally in a potted plant, when a root hits the side of the pot it is deflected and roots start to grow in a spiral round the pot. Over time, these roots grow into a dense mat which does not absorb water and nutrients very well, and may be prone to rotting and disease. The design of the airpot directs roots, when they reach the edge of the pot, to poke through the holes, where of course they dry out and are ‘pruned’ by the air. This encourages new roots to grow from the base of the plant, so instead of a thick unhealthy coil of roots at the bottom of the pot you end up with a mesh of new healthy roots spreading throughout the soil. Unfortunately the air-pots are rather expensive, especially if I wanted some shipped to Japan.
It occurred to me that crocheted plastic bags would have a similar effect – the rounded bumps of the stitches would encourage root tips to grow through the holes between the stitches, while the holes would give really good drainage and the layers of plastic, with air trapped both in and between the stitches, would insulate the roots from extremes of hot and cold. And best of all, it would be practically free and environmentally friendly - so I give you, the crocheted plarn planter!
Remove these ads by
Signing UpStep 1Materials
You’ll need:
- plastic grocery bags – I made a pot 5in in diameter and about 4in tall, which took 10 bags. It doesn't matter if you have a mix of different thicknesses and sizes, you can adjust the width of your strips to get a consistent yarn
- scissors
- crochet hook – plarn is tough on the hands so a hook with a chunky handle will be better
7
comments
Add Comment
Applejuice11
says:
Add Comment
